General Home Automation wireless security alternatives..
Subject Author Date
wireless security alternatives.. wle 06-16-05
Posted by wle on June 16, 2005, 11:02 pm
so, i had a powerhome ps561 console.
it died.
awkwardly and slowly.
now i can;t install any devices on it.
what is a good alternative?
i need it to take input from the wireless door and window sensors,
remotes, and keychain remotes, and do the alarm thing to x10
lamp controllers, and the powerhorn siren. and maybe do that telephone
dialout thing, and room listen-in function.
i never liked the thing;s user interface.
very clunky.
and it seemed to drain the backup battery even though it was always
on ac power.
so what can do what the ps561 was doing?
i don;t really want a computer to be involved, plus as i said it needs
to receive signals from the existing sensors and remotes.
thx
wle.
Posted by Dave Houston on June 17, 2005, 4:59 pm
I know next to nothing about X-10 Security consoles but your sensors, etc.
will not work with anything other than another console from X-10.
>it died.
>very clunky.
>on ac power.
>thx
>wle.
Posted by Frank Olson on June 17, 2005, 5:46 pm
> it died.
> very clunky.
> on ac power.
> thx
> wle.
You're SOL as far as trying to find a security panel that's compatible with
your existing sensors unless it's a direct replacement for the same unit you
have. Manufacturers of modern alarm panels don't make their wireless
products to "cross" between panels of a different make. Most have their own
ideas of how best to ensure the integrity of their equipment and it also
prevents "cross-talk" when you run into "neighboring" installations.
Have a look at the DSC line of products (http://www.dsc.com), particularly
the "Power" series. They're fairly easy to program and will interface with
your existing X-10 automation components. These products are available from
a wide variety of online stores and home automation companies, or
alternatively, you can purchase the components from a local alarm dealer who
may also be in the position of assisting you (for a small fee of course)
should you run into any problems.
Good luck!!! :-))
Similar ThreadsPosted
wireless security alternatives.. June 16, 2005, 11:02 pm
802.11 wireless home security June 10, 2005, 11:40 pm
Recommend Wireless Web Based Security Cam? November 4, 2007, 7:56 am
Complete Wireless Security System : Recommend? April 4, 2005, 7:35 am
FS: 4-camera wireless spycam security system June 29, 2008, 12:15 am
Wireless 32 Protection Area Security Alarm System January 21, 2006, 8:52 pm
Swann Night Hawk wireless security camera? March 10, 2007, 2:51 am
X-10 alternatives for 220V equipment? September 6, 2006, 8:21 am
Telecommunications Alternatives For The Distributed Workforce (March 2006) April 26, 2006, 8:31 am
Wireless 485 August 12, 2005, 8:39 am
Wireless PC Speakers February 15, 2005, 11:09 am
x10 vs wireless network February 24, 2006, 7:42 am
Wireless thermostat March 10, 2006, 12:08 am
Transmit Wireless RCA June 20, 2006, 9:34 am
wireless thermostat? September 2, 2006, 3:33 pm
