General Home Automation translator question
Subject Author Date
translator question Dave Houston 01-20-06
Posted by Dave Houston on January 20, 2006, 10:59 am
I'm considering tackling the TW523 emulator translator.
Which of the controllers which might make use of this send for all three
phases and which only send for a single phase? I know ADI only sends for one
and think HAI is the same. I'm not sure this is critical but would like to
know, just in case.
My thoughts are to make it with TTL input/output and with mutiple serial
input/output ports. That way it could interface with any PLC (or other)
system for which there is a serial interface and for which the translator
knows the protocol.
If I do this it will be a DIY project and will probably use a ZX-24
processor so it won't be as cheap as a PIC based device. The ZX-24 has one
hardware UART and can support up to four interrupt driven full-duplex
software UARTs (9600 bps or less) so it could deal with multiple
protocols/devices and be programmable from a PC serial port. It's code
execution speed is 10x as fast as the original BX-24 and has a more
efficient compiler so there should be ample EEPROM available for user
instructions.
I'm willing to try to develop the code and to design a printed circuit board
but I'm not willing to buy all of the various hardware needed to develop and
test (and reverse engineer protocols) for the new PLC (and other) systems.
I envision it as a "monkey see, monkey do" system that listens for inputs on
any port and translates it to whatever action on whatever port the user
specifies. In essence, it would just be a multilingual switchboard.
I can probably do most of the development using a board I already have
(BX24-AHT). That way the board design could come after the coding and list
of devices supported is near completion or it might turn out that the
existing board design will prove adequate with some simple surgery.
I think it could support...
TW523
CM11A
CPU-XA, Ocelot, Leopard
2414S PowerLinc V2 Serial (if I can reverse engineer the protocol)
UPB Powerline Interface Module
LynX-10 PLC
Other serial interfaces (if the protocol is available)
X-10 RF (if all the above leave enough memory)
I need to keep this as simple as possible so as not to put too much pressure
on my health so would probably take on one protocol at a time.
I've had some preliminary discussion with the ZX-24 developer about
publishing this as an Application Note on the ZX-24 web site. I do not want
to set up and maintain another web page.
Posted by BruceR on January 20, 2006, 2:05 pm
Sounds like an ambitious project well worth the effort. The TTL
interface would, IMO, be far superior to translating PLC signals. I'd
be willing to participate financially and otherwise. Let me know how I
can help.
nobody@whocares.com
> three phases and which only send for a single phase? I know ADI only
> sends for one and think HAI is the same. I'm not sure this is
> critical but would like to know, just in case.
> serial input/output ports. That way it could interface with any PLC
> (or other) system for which there is a serial interface and for which
> the translator knows the protocol.
> has one hardware UART and can support up to four interrupt driven
> full-duplex software UARTs (9600 bps or less) so it could deal with
> multiple protocols/devices and be programmable from a PC serial port.
> It's code execution speed is 10x as fast as the original BX-24 and
> has a more efficient compiler so there should be ample EEPROM
> available for user instructions.
> circuit board but I'm not willing to buy all of the various hardware
> needed to develop and test (and reverse engineer protocols) for the
> inputs on any port and translates it to whatever action on whatever
> port the user specifies. In essence, it would just be a multilingual
> switchboard.
> list of devices supported is near completion or it might turn out
> that the existing board design will prove adequate with some simple
> surgery.
> TW523
> CM11A
> LynX-10 PLC
> pressure on my health so would probably take on one protocol at a
> time.
> not want to set up and maintain another web page.
Posted by Dave Houston on January 20, 2006, 3:01 pm
Actually, it's not that ambitious. I already have BX-24 code (which only
requires minor changes for the ZX-24) for most of the X-10 stuff and the
rest is just a matter of getting the serial protocols. It's basically just a
few lookup tables. The BX24-AHT board is already setup for the PC link plus
three 12V RS232 ports. A fourth can be added with a few jumpers in the
location designed for the RS-485 driver (which won't be used otherwise).
When the time comes, you can loan me a 2414S and lamp module or two for
testing. This one would be much simpler if they'd just change the terms of
their license. ;)
I can also include X-10 RF (and Bobby G's housecode switcheroo) rather
easily. My brain was locked into a particular path as I was writing the
first post. Some lunch unlocked it.
I think the UPB and LynX-10 PLC protocols are published. Any other serial
controller (9600 bps or less) for which I can get the protocol is a
candidate. I'd rather not have to reverse engineer them.
The firmware can be changed via a PC serial connection so it can be upgraded
as new devices come along. I may get surprised but I think the ZX-24 has
ample speed and memory to handle this and more.
>can help.
>From:Dave Houston
>nobody@whocares.com
>> switchboard.
>> surgery.
>> TW523
>> CM11A
>> LynX-10 PLC
>> time.
Posted by BruceR on January 20, 2006, 3:17 pm
I should have clarified - it would be ambitious for ME ;). I'll be
happy to loan you my 2414U and some modules. Note that I have the USB
rather than the Serial version of the 2414. Hope that will still fit the
bill. If not, I'll get you one.
nobody@whocares.com
> only requires minor changes for the ZX-24) for most of the X-10 stuff
> and the rest is just a matter of getting the serial protocols. It's
> basically just a few lookup tables. The BX24-AHT board is already
> setup for the PC link plus three 12V RS232 ports. A fourth can be
> added with a few jumpers in the location designed for the RS-485
> for testing. This one would be much simpler if they'd just change the
> terms of their license. ;)
> the first post. Some lunch unlocked it.
> serial controller (9600 bps or less) for which I can get the protocol
> is a candidate. I'd rather not have to reverse engineer them.
> upgraded as new devices come along. I may get surprised but I think
> the ZX-24 has ample speed and memory to handle this and more.
>> I'd be willing to participate financially and otherwise. Let me know
>> how I can help.
>> From:Dave Houston
>> nobody@whocares.com
>>> which the translator knows the protocol.
>>> port. It's code execution speed is 10x as fast as the original
>>> BX-24 and has a more efficient compiler so there should be ample
>>> EEPROM available for user instructions.
>>> switchboard.
>>> have (BX24-AHT). That way the board design could come after the
>>> coding and list of devices supported is near completion or it might
>>> turn out that the existing board design will prove adequate with
>>> TW523
>>> CM11A
>>> protocol) UPB Powerline Interface Module
>>> LynX-10 PLC
>>> time.
Posted by Dave Houston on January 20, 2006, 4:27 pm
No, you'll need a serial version. A microcontroller just doesn't have the
horsepower to be a USB host.
>From:Dave Houston
>nobody@whocares.com
>>> how I can help.
>>> From:Dave Houston
>>> nobody@whocares.com
>>>> switchboard.
>>>> TW523
>>>> CM11A
>>>> LynX-10 PLC
>>>> time.
Similar ThreadsPosted
translator question January 20, 2006, 10:59 am
X10 Code Translator July 21, 2006, 12:01 pm
Re: IR Learning Translator February 18, 2007, 10:59 am
Smarthome Insteon Translator December 17, 2005, 4:17 pm
Press Release: X-10 to UPB Translator (Two-Way) December 18, 2005, 8:38 pm
X10 to Insteon Translator is shipping! December 22, 2005, 12:44 am
re:Smarthome Insteon Translator January 28, 2006, 7:30 pm
Commercial X-10 to INSTEON translator shipping December 3, 2007, 10:34 am
Product Idea: X10 to UPB/Zigbee/Insteon translator October 29, 2005, 9:11 pm
question October 24, 2005, 11:59 am
HI Im New and have a question April 25, 2006, 3:00 pm
Question of the day September 28, 2006, 11:12 pm
X10 Camera question February 9, 2005, 4:58 pm
Relays Question February 17, 2005, 4:56 am
X10 Control Question March 29, 2005, 8:36 am
