I have just had a pool installed and I'd like to automate one of the valves. It is a Jandy Neverlube valve, with a 2" pipe.
The lights are already on X10 from the electrician, and all I want to do is automate that one valve. I don't want a more expensive control system, just a X10 interface.
So my question is, I can get the Jandy or similar control actuator, but what interface does the actuator have, is it a simple X10 on/off singal? How would this work?
Any help would be much appreciated.
Thanks,
Carl snipped-for-privacy@austin.rr.com
