Search ABC from Firefox
Mar 01, 2005 10 Replies
Jump to replies (10)
- Nehmo - It's just multiposting, not spam. But I'll take the opportunity to correct a mistake I made in my example. It should be: F6 abc honest man .. The "abc" is the keyword for the bookmark. I mistakenly had only "a" in my original post.
-- ********************* * Nehmo Sergheyev * *********************
By so doing, you will void your warranty. If you're not using IE, you're using dirt.
Search ABC from Firefox open original image
Get Firefox (if you don't already have it)
Go to (and you might as well subscribe) to the Google Groups version of news:alt.building.construction >
Place your cursor in the Search This Group box on the upper right of the page >
Rightclick > Add Keyword for this Search > The "Add Bookmark" box will display >
Fill in an appropriate name, such as "alt.building.construction ng" >
Fill in a Keyword such as a simple "abc" >
OK button > You're done!
To Search.
F6 (to place the focus in the Address Bar of Firefox; you don't need to do this if the focus is already there)>
Type "abc", followed by a space, and whatever you want to search ABC for. For example:
F6 a honest man
This would search Google's archive of ABC for an honest man.
You can use the Google Group's search techniques,
for example: F6 a author: snipped-for-privacy@hotmail.com (not saying you'd want to go there) would give you my posts
You can use this procedure for other newsgroups search boxes or for non-newsgroup search boxes too.
"Nehmo Sergheyev" wrote
Doesn't work! I tried to find a newsgroup and it came up empty. The newsgroup was:
alt.a-holesThatSpamNewsgroupsNamedNehmo
"Mmmmmmmmmmmmmmmmmmmmmm.......spammmmmmmm...."
"Dr. Hardcrab" wrote
Now try: Type "abc", followed by a space, and whatever you want to search ABC for. For example: abc king a-hole
You will find Nehmo's name come up.
Damn iffin it don't!!!
- johnny -
- Nehmo - Nope. I tried the search. Rico dJour comes up. It's not my fault, Rico.
You 'kink pr1ck! Void your warranty?? What warranty??
You _and_ the OP can FOAD.
