If I need a 45 Inch antenna does the diameter of the rod matter?
Threaded View
Suppose  schema says 16 ga copper,  I want to use 1/4 Aluminum rod.   Will it do
the same job?
Ian
Re: If I need a 45 Inch antenna does the diameter of the rod matter?
On Fri, 27 Nov 2015 14:38:00 +0000, semibogus
Yes.  However, you can't take that to extremes.  But for most
applications, a small change in diameter won't matter.
Site Timeline
