I have a wood shop in my basement and would like to automate the startup/shutdown of my dust collector unit. It is a 220v unit plumbed to 4 separate power tools (3 are 110v, 1 is 220v). My ideal configuration would be to have the dust collector start immediately when any of the 4 tools are powerd on, and remain on for a few seconds after the tool is turned off.
I have been using a keychain remote control with an X10 system to manually control the unit. For some reason I just fried the 2nd appliance control module since I've had the system. Instead of replacing the manual system I am hoping to automate.
I am familiar with electronics, including relays and timer circuits, and am interested in any sugggestions on how to accompish this task. In particular, is there a way to detect when the motor in any of the tools starts without having to wire directly into the switch? Is there a way to do this without running additional wiring to all of the tools?
Thanks in advance for any advice/guidance!
