Fiber Optics strongly guided fiber?
Subject Author Date
strongly guided fiber? psvanvic 05-01-07
Posted by psvanvic on May 1, 2007, 2:14 pm
I am working on modeling some fiber for my dissertation and something
came up in doing my homework on standard step index smf fiber. Many
of the texts I have referenced and done the standard weakly guided
solutions for fibers all use the "weakly guided assumption" and the
dispersion relationship to search for modes...
What happens if a fiber is strongly guided? I know the modeling
breaks down for that type of solution technique...but what happens in
reality with a strongly guided fiber? Why are they not desirable in
industry..for telecom etc?
I am a mechanical engineer doing stress sensor research...so I didn't
have an EM class. Any help would be appreciated..this is just a
question that I have, not really related to my research.
Thanks,
Pat.
Posted by Phil Hobbs on May 1, 2007, 2:34 pm
> Thanks,
> Pat.
The long answer:
In any lossless optical system, the product of the area and projected
solid angle of any single mode is always lambda**2/2. Stronger guiding
equals a wider angular acceptance, which increases the projected solid
angle. To keep a fibre single-mode with stronger guiding, you have to
decrease the core diameter. This has the following disadvantages:
1. Tighter mechanical tolerances--if you halve the diameter, you have
to align twice as accurately.
2. Higher losses at splices--you can't readily make the cladding index
very much lower than that of fused silica (~1.46), so you have to
increase the core index, which leads to higher reflection losses.
3. Higher losses due to microbending--roughness at the core-cladding
boundary causes much higher scattering when the index discontinuity is
large and the field strength is high, as in small-diameter, high-index
fibre.
All of these things increase the cost of transmission systems, which is
why very weak guiding is used.
Strong guiding is good for lots of things too:
1. More light per unit area--in a multimode fibre, you can pack more
modes (and hence more light from an incoherent source) into the same
fibre diameter with stronger guiding.
2. Lower bending loss--stronger guiding means you can turn tighter
corners without losing light. Silicon-core waveguides used in optical
ICs (at 1.55 micron wavelength) are about 0.45 microns wide and 0.2
microns tall, and you can make a 2-um radius bend with low loss. For
fibre it isn't usually that big a deal, because bend radii are also
limited by mean time to fracture (especially if the fibre can become wet).
3. Stronger interaction with perturbations, e.g. in sensors. This is
the flip side of the increased microbend loss. Sometimes you _want_
increased sensitivity to what's going on at the surface.
The modelling thing can be fixed up to work with strongish
guiding--though it gets much harder with silicon guides.
Cheers,
Phil Hobbs
Strongly guided fibre is good for multimode, because you can get more
light into the fibre--more modes for a given diameter.
Posted by Phil Hobbs on May 1, 2007, 2:51 pm
angle.
Minor correction: the invariant is n**2*A*Omega-prime. Forgot the
n-squared.
Cheers,
Phil Hobbs
Posted by mechpat on May 1, 2007, 3:22 pm
Thanks for a great explanation.
I have one theoretical question then. If you could dope the clad with
Fluorine or something that could drop the index a bunch, keep the core
the same size...you could have a strongly guided fiber without most of
the problems you mentioned though right?
Thanks,
Pat.
> angle.
> n-squared.
> Cheers,
> Phil Hobbs
Posted by Phil Hobbs on May 1, 2007, 8:13 pm
The lowest-index material that isn't water soluble is magnesium
fluoride, with N=1.38 or so. Thus you can't really go that low by this
method. You'd win a little bit that way, since the microbending loss
wouldn't be quite as bad, due to the larger diameter that this method
could afford. The index contrast at the core-cladding boundary would
still be large, though, so the scattering would still be strong.
Cheers,
Phil Hobbs
Similar ThreadsPosted
strongly guided fiber? May 1, 2007, 2:14 pm
Sell Fiber Optic Splice Closure,Splice Enclosure,Fiber Optic Closure,Optic Fiber Cable Connection Box December 1, 2005, 11:58 pm
Fiber to Fiber Coupling April 22, 2007, 2:26 am
Fiber in NYC October 1, 2005, 7:11 pm
where can i buy some bragg fiber September 21, 2005, 1:22 am
Identifying fiber September 28, 2005, 8:15 am
Fiber Cladding November 19, 2006, 6:58 am
Need Fiber For My Artwork August 16, 2007, 4:03 pm
Mid IR fiber supplier November 13, 2007, 3:56 am
switch for fiber December 23, 2007, 5:21 pm
Locking Fiber SMA August 25, 2008, 9:05 am
fiber optics link in ns-2 September 14, 2005, 9:05 am
where is bragg fiber for sale?? September 21, 2005, 1:06 am
where is bragg fiber for sale?? September 21, 2005, 1:10 am
Re: Please help me i've to connectorized an optic fiber September 7, 2006, 10:47 am
