Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by glnsk8ter on December 18, 2006, 10:24 am
Please log in for more thread options I am trying to diagnose a slow email issue from various office scanners that can perform scan to email from their control panel, used to work fine now their is an intermittent situation where scan a page once, goes fine, rescan it again and it may take minutes or hours. local email server. I have a packet capture, but I just noticed there doesn't seem to be a way to attach it. I see sections where a previous segment loss message from is sent from scanner. then an awk from email server then some packets of message body (varies from 3 to 7) then duplicate awk packets equal in quanity to the number of message body packet sent. then a single fast retransimission of message body from scanner is sent to email server then more packets without any issues, then then the whole set of messages above again. | |||||||||||||
Posted by on December 26, 2006, 10:39 am
Please log in for more thread options glnsk8ter wrote: In a modern ethernet network the most likely cause is a duplex missmatch. Set everything to auto speed/auto duplex and try again. Check all interfaces for hardware layer errors CRC, align/frame, short. If you have unmanaged network equipment check the end stations. "netstat -e" works sometimes - If that doesn't identify the issue get managed network equipment or randomly change things until it goes away. Second most likely is bad cable or NIC. | |||||||||||||
| Similar Threads | Posted |
| slow smtp issue/packet capture | December 18, 2006, 10:24 am |
| Packet capture | November 28, 2007, 12:07 am |
| Slow down of internet service | November 27, 2005, 7:08 pm |
| slow TCP connections due to very different speed of segments? | March 10, 2005, 5:08 am |
| Using Jumbo Frames & Gigabit - Actual BPS is slow ! | September 17, 2004, 10:39 am |
| Help - how to adjust capture buffer size of Ethereal? | October 1, 2004, 12:00 am |
| Ethereal Capture-Filter for web address filtering | October 25, 2004, 6:51 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> it.
> I see
> sections where
> packet sent.
> email server
> above again.
