I have a small problem here, but first some background on my network...
I have several VLANS setup on a switch (WS-C3548-XL-EN) as follows: VLAN 10 is for network devices (Internet router, core router, etc.) VLAN 100 is for servers VLAN 200 is for workstations VLAN 210 is for wireless.
Various ports on the switch are tagged for their respective VLANS. Fa0/1 is set as the trunk to the 2621.
Now when I am copying large files between a workstation (on workstation vlan) and my fileserver (on server vlan) I seem to notice that the Internet connectivity hiccups. It doesn't exactly go down until the transfer is done, but it does seem to lag a great deal in small bursts.
Now I seem to think this may be an issue with the fact that my core router (the 2621) cannot handle all the packets on the trunk interface to it. (trying to route between the workstation and server vlan, while also routing between workstation vlan and network devices vlan).
I guess after that description of my situation, my question would be either or both of the following:
- Is there a way to implement some QoS on the switch or router to ensure the copies from workstations to servers don't kill the available throughput?
- Is there any chance that switching from ISL to .1Q vlans would make any difference (no I am not using, nor plan to use, anything other than cisco gear)
Any help would be greatly appreciated! Especially any sample config changes!
Below is a copy of my configs...
INTERNET----(CISCO 871)-----(CISCO 2621)-----(CISCO 3548)-----LAN
************************************************************************************************************ ************************************************************************************************************ Cisco 2621: ************************************************************************************************************ ************************************************************************************************************corertr#show run Building configuration...
Current configuration : 1492 bytes ! version 12.3 service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname corertr ! boot-start-marker boot-end-marker ! enable secret 5 [Ommited] enable password 7 [Ommited] ! no aaa new-model ip subnet-zero ip cef ! ! ip domain name edgenet.local ip name-server 172.16.1.10 ip name-server 172.16.1.11 ! ip audit po max-events 100 ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! interface FastEthernet0/0 ip address 10.0.0.2 255.255.255.252 duplex auto speed auto ! interface FastEthernet0/1 no ip address duplex auto speed auto ! interface FastEthernet0/1.10 encapsulation isl 10 ip address 10.1.1.1 255.255.255.0 no ip redirects no snmp trap link-status ! interface FastEthernet0/1.100 encapsulation isl 100 ip address 172.16.1.1 255.255.255.0 no ip redirects no snmp trap link-status ! interface FastEthernet0/1.200 encapsulation isl 200 ip address 172.16.200.1 255.255.255.0 ip helper-address 172.16.1.10 no ip redirects no snmp trap link-status ! interface FastEthernet0/1.210 encapsulation isl 210 ip address 172.16.210.1 255.255.255.0 ip helper-address 172.16.1.10 no ip redirects no snmp trap link-status ! router rip network 10.0.0.0 network 172.16.0.0 ! no ip http server no ip http secure-server ip classless ip route 0.0.0.0 0.0.0.0 10.0.0.1 ! ! logging 172.16.1.7 ! snmp-server community public RO ! ! ! ! ! line con 0 line aux 0 line vty 0 4 password 7 [Ommited] login ! ! end
corertr#
************************************************************************************************************ ************************************************************************************************************ Cisco 3548: ************************************************************************************************************ ************************************************************************************************************coreswitch#show run Building configuration...
Current configuration: ! version 12.0 no service pad service timestamps debug uptime service timestamps log uptime service password-encryption ! hostname coreswitch ! enable secret 5 [Ommited] enable password 7 [Ommited] ! ! ! ! ! clock timezone EST -5 ! ip subnet-zero ip domain-name edgenet.local ip name-server 172.16.1.10 ip name-server 172.16.1.11 ! ! ! interface FastEthernet0/1 description TRUNK TO CORE ROUTER switchport trunk allowed vlan 1,10,100,200,210,1002-1005 switchport mode trunk ! interface FastEthernet0/2 ! interface FastEthernet0/3 ! interface FastEthernet0/4 ! interface FastEthernet0/5 ! interface FastEthernet0/6 ! interface FastEthernet0/7 ! interface FastEthernet0/8 ! interface FastEthernet0/9 ! interface FastEthernet0/10 ! interface FastEthernet0/11 ! interface FastEthernet0/12 ! interface FastEthernet0/13 ! interface FastEthernet0/14 ! interface FastEthernet0/15 ! interface FastEthernet0/16 ! interface FastEthernet0/17 ! interface FastEthernet0/18 ! interface FastEthernet0/19 ! interface FastEthernet0/20 ! interface FastEthernet0/21 ! interface FastEthernet0/22 ! interface FastEthernet0/23 ! interface FastEthernet0/24 ! interface FastEthernet0/25 ! interface FastEthernet0/26 switchport access vlan 200 ! interface FastEthernet0/27 switchport access vlan 200 ! interface FastEthernet0/28 switchport access vlan 200 ! interface FastEthernet0/29 switchport access vlan 200 ! interface FastEthernet0/30 switchport access vlan 200 ! interface FastEthernet0/31 switchport access vlan 200 ! interface FastEthernet0/32 switchport access vlan 200 ! interface FastEthernet0/33 switchport access vlan 210 ! interface FastEthernet0/34 switchport access vlan 210 ! interface FastEthernet0/35 ! interface FastEthernet0/36 ! interface FastEthernet0/37 ! interface FastEthernet0/38 ! interface FastEthernet0/39 ! interface FastEthernet0/40 ! interface FastEthernet0/41 ! interface FastEthernet0/42 ! interface FastEthernet0/43 ! interface FastEthernet0/44 switchport access vlan 100 ! interface FastEthernet0/45 switchport access vlan 100 ! interface FastEthernet0/46 switchport access vlan 100 ! interface FastEthernet0/47 switchport access vlan 100 ! interface FastEthernet0/48 switchport access vlan 100 ! interface GigabitEthernet0/1 ! interface GigabitEthernet0/2 ! interface VLAN1 no ip address no ip directed-broadcast no ip route-cache shutdown ! interface VLAN10 ip address 10.1.1.249 255.255.255.0 no ip directed-broadcast no ip route-cache ! ip default-gateway 10.1.1.1 no ip http server snmp-server engineID local 00000009020000046DF94F00 snmp-server community public RO ! line con 0 login transport input none stopbits 1 line vty 0 4 password 7 [Ommited] login line vty 5 15 password 7 [Ommited] login ! end
coreswitch# coreswitch# coreswitch# coreswitch#show vlan VLAN Name Status Ports
1 default active Fa0/2, Fa0/3, Fa0/4, Fa0/5, Fa0/6, Fa0/7, Fa0/8, Fa0/9, Fa0/10, Fa0/11, Fa0/12, Fa0/13, Fa0/14, Fa0/15, Fa0/16, Fa0/17, Fa0/18, Fa0/19, Fa0/20, Fa0/21, Fa0/22, Fa0/23, Fa0/24, Fa0/25, Fa0/35, Fa0/36, Fa0/37, Fa0/38, Fa0/39, Fa0/40, Fa0/41, Fa0/42, Fa0/43, Gi0/1, Gi0/2 10 network_devices_vlan active 100 server_vlan active Fa0/44, Fa0/45, Fa0/46, Fa0/47, Fa0/48 200 workstation_vlan active Fa0/26, Fa0/27, Fa0/28, Fa0/29, Fa0/30, Fa0/31, Fa0/32 210 wireless_vlan active Fa0/33, Fa0/34 1002 fddi-default active 1003 token-ring-default active 1004 fddinet-default active 1005 trnet-default activeVLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0 10 enet 100010 1500 - - - - - 0 0 100 enet 100100 1500 - - - - - 0 0 200 enet 100200 1500 - - - - - 0 0 210 enet 100210 1500 - - - - - 0 0 1002 fddi 101002 1500 - - - - - 0 0 1003 tr 101003 1500 - - - - - 0 0 1004 fdnet 101004 1500 - - - ieee - 0 0 1005 trnet 101005 1500 - - - ibm - 0 0 coreswitch#
