Third part Flash memory card.
It is possible to install third part flash memory card for a router 3620? Original ones seem no to be found and quite expensive at that time.
Any suggestions? I'm looking for 16-20 Mbytes size.
Alex.
AM
cdw.com sells them, and yes they are ALOT cheaper and do work...
Foad
Officially speaking, it will invalidate your Smartnet (if you have one)
Unofficially, it works fine. "quite expensive" is putting it mildly.
Hansang Bae
