OP TP270 10'' writing to memory flash problem
Jul 29, 2006 1 Replies
OP TP270 10'' writing to memory flash problem open original image
hi, I am working on WinCC Flexible 2005 and with simulator script to write on hdd and read from hdd works, but in real panel doesn't :// I got message ActiveX component can't create object... problem is with set oFs = CreateObject("Scripting.FileSystemObject") command. where is the problem ? thx
Make sure Windows Scripting components are installed. These files are usually located in the Windows/System32 directory. (scrrun.dll and possibly might need msscript.ocx)
Check with the WinCC Flexible 2005 and with simulator script installs. If they use scripting then they should have told you how to get it installed.
