Hi: I posted the "static routing question" but probably didn't give enough information.
I'm trying to add an Address Translation Rule to take https traffic from the outside IF and route it to a specific IP on the inside interface, using the PDM 3.0 on a Pix 506e.
I specify the original host/network as:
IF: inside IP address: 192.168.0.100 Mask: 255.255.255.255
and set "translate address on interface" to:
IF: Outside Static IP Address: Interface IP "Redirect Port" is checked TCP is checked Original Port: 443 Translated Port: 443
When I click "OK" I get a popup "Overlaping/Redundant translation rule" "This static port mapping translation rule is overlapping with a dynamic address translation for inside: 0.0.0.0/0.0.0.0(any) uing global pool 1. Do you still wish to proceed?"
"global pool 1" is a VPN pool
I click "stop" at this point for fear of mucking something up...what do I need to do to set this up correctly?
