Hi
i have a problems with one of my cisco 7204VXR/NPE400:
C7204#sh interfaces gigabitEthernet 0/0 GigabitEthernet0/0 is up, line protocol is up Hardware is i82543 (Livengood), address is 000c.cf56.6008 (bia
000c.cf56.6008) Description: Link with C6500 Internet address is xx.xx.xx.xx/30 MTU 1548 bytes, BW 1000000 Kbit, DLY 10 usec, reliability 255/255, txload 1/255, rxload 12/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, 1000Mb/s, link type is autonegotiation, media type is SX output flow-control is XON, input flow-control is XON ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters 14:23:01 Input queue: 0/75/0/1 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 47152000 bits/sec, 6064 packets/sec 5 minute output rate 7602000 bits/sec, 1489 packets/sec 363166224 packets input, 238477403742 bytes, 0 no buffer Received 20953 broadcasts, 0 runts, 0 giants, 0 throttles 133 input errors, 0 CRC, 0 frame, 24 overrun, 109 ignored 0 watchdog, 20953 multicast, 0 pause input 0 input packets with dribble condition detected 182611031 packets output, 112428021686 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 unknown protocol drops 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier, 0 pause output 0 output buffer failures, 0 output buffers swapped outi have a quantity of: 133 input errors and 109 ignored
And i don't know why. on the Cisco 6500, no errors.
C7204-1.STE01#sh ver Cisco IOS Software, 7200 Software (C7200-JS-M), Version 12.4(19), RELEASE SOFTWARE (fc1) Technical Support:
ROM: System Bootstrap, Version 12.2(4r)B2, RELEASE SOFTWARE (fc2) BOOTLDR: 7200 Software (C7200-KBOOT-M), Version 12.1(8a)E, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
C7204 uptime is 45 weeks, 4 days, 19 hours, 56 minutes System returned to ROM by power-on System restarted at 09:34:32 UTC Sat Dec 20 2008 System image file is "disk0:c7200-js-mz.124-19.bin"
Cisco 7204VXR (NPE400) processor (revision A) with 491520K/32768K bytes of memory. Processor board ID 29812082 R7000 CPU at 350MHz, Implementation 39, Rev 3.3, 256KB L2 Cache
4 slot VXR midplane, Version 2.7Last reset from power-on
PCI bus mb0_mb1 (Slots 0, 1, 3 and 5) has a capacity of 600 bandwidth points. Current configuration on bus mb0_mb1 has a total of 600 bandwidth points. This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4, 6) has a capacity of 600 bandwidth points. Current configuration on bus mb2 has a total of 600 bandwidth points This configuration is within the PCI bus capacity and is supported.
Please refer to the following document "Cisco 7200 Series Port Adaptor Hardware Configuration Guidelines" on Cisco.com for c7200 bandwidth points oversubscription and usage guidelines.
1 Ethernet interface 2 FastEthernet interfaces 2 Gigabit Ethernet interfaces 125K bytes of NVRAM.215040K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
8192K bytes of Flash internal SIMM (Sector size 256K). Configuration register is 0x2102Not a problems of bandwidth point ...
C7204-1.STE01#sh proc CPU utilization for five seconds: 13%/12%; one minute: 16%; five minutes: 15%
not a full charge of the router .....
but i see:
C7204#sh buffers Buffer elements: 1118 in free list (1119 max allowed) 470134315 hits, 0 misses, 619 created
Public buffer pools: Small buffers, 104 bytes (total 50, permanent 50, peak 284 @ 7w0d): 45 in free list (20 min, 150 max allowed) 342390803 hits, 79105 misses, 60160 trims, 60160 created 20208 failures (0 no memory) Middle buffers, 600 bytes (total 25, permanent 25, peak 391 @ 7w0d): 21 in free list (10 min, 150 max allowed) 52903004 hits, 34984 misses, 47823 trims, 47823 created 7142 failures (0 no memory) Big buffers, 1536 bytes (total 50, permanent 50, peak 116 @ 7w0d): 50 in free list (5 min, 150 max allowed) 83483682 hits, 1234 misses, 1530 trims, 1530 created 570 failures (0 no memory) VeryBig buffers, 4520 bytes (total 10, permanent 10, peak 13 @ 7w0d): 10 in free list (0 min, 100 max allowed) 11025564 hits, 338 misses, 18 trims, 18 created 338 failures (0 no memory) Large buffers, 5024 bytes (total 1, permanent 0, peak 4 @ 7w0d): 1 in free list (0 min, 10 max allowed) 20 hits, 318 misses, 2856 trims, 2857 created 318 failures (0 no memory) Huge buffers, 18024 bytes (total 1, permanent 0, peak 5 @ 5w6d): 1 in free list (0 min, 4 max allowed) 236 hits, 307 misses, 2854 trims, 2855 created 303 failures (0 no memory)
In "Public buffer pools" a lot of "failures".
i see to: Big buffers, 1536 bytes (total 50, permanent 50, peak 116 @ 7w0d):
total= 50 Permanent = 50 and peak at 116
i don't know what is this detail, if i understand, the system want use in peak 116 and he have only 50 ?
thanks for your help Mag
