DC Input on Cisco Catalyst 2900XL
Sep 17, 2005 1 Replies
Hello,
I have just been given a 'dead' Cisco Catalyst 2900XL that I would very much like to use in my own lab. The internal power supply on it has blown so I would like to use the DC Input connection on the back and connect it to a standard ATX power supply because its 5/12v would do the trick. Unless somebody knows of just a simple adapter, but I have been scouring the net and can't find one.
The issue is that I need to know the pinouts of the DC Input receptacle on the back of the switch.
Anybody know them or know where I can find them?
Cheers and thanks in advance!
It's 48vdc. Made and designed for a redundent power supply setup or a telco. You should be able to get a replacment power supply on ebay for very cheap$$
