7204VXR ipsec performance
Nov 28, 2007 6 Replies
Jump to replies (6)
Hello max,
Do you have anything on performance on this router with only basic routing?
Make sure to use VAM card with Ipsec for improved performance.
:-)) well, I do not have 20K$ for this card
note they dont even post numbers for 7200 without encryption hardware.
seems a bit crazy to spend more than $20k on the router, and then not use the accelerator which gives you reasonable thruput.
Anyway - then you have the wrong box. try a 28xx, 3825 or 3845 with the built in IPsec hardware.
more perf numbers for other things:
well if G1/VAM2+ can do the job .... and it looks like it can ... thanks for this doc
