sigh, I really dont know what is going on , lol
I have a point to point 2600 circuit that now is showing a "reset" on serial1/1 - I have never seen this before?
here is a show int serial1/1 - anyone point me at what I should be trying to do next to work this out? thanks
Serial1/1:0 is reset, line protocol is down Hardware is DSX1 Description: PTP to LA Internet address is 10.10.10.1/30 MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation PPP, loopback not set Keepalive set (10 sec) LCP Closed Closed: IPCP, CDPCP Last input 00:38:06, output 00:37:56, output hang never Last clearing of "show interface" counters 4w1d Input queue: 0/75/3728106/0 (size/max/drops/flushes); Total output drops:
2824Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/1/256 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) Available Bandwidth 1152 kilobits/sec 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 463 packets input, 13323 bytes, 0 no buffer Received 0 broadcasts, 887553 runts, 0 giants, 0 throttles 3728130 input errors, 393976 CRC, 3334205 frame, 0 overrun, 0 ignored,
1842 667 abort 618 packets output, 15853 bytes, 0 underruns 0 output errors, 0 collisions, 671 interface resets 0 output buffer failures, 0 output buffers swapped out 38 carrier transitions Timeslot(s) Used:1-24, Transmitter delay is 0 flagsand here is the show on the controller
Controller 1 is type: T1 with CSU interface in slot 1 Serial interface 1/1:0 Munich32 version 3.4 Total chip configuration successes: 2810, failures: 0, timeouts: 0 Interrupt Queue Element(index=198): interrupt is enabled 0x0000000 0x0000000 0x0000000 0x0000000 0x0000000 0x0000000 0x0000000 0x0000000 0x0000000 0x0000000 0x0000000 0x0000000 0x0000000 0x0000000 0x0000000 0x0000000 0x0000000 0x0000000 0x0000000 0x0000000 0x0000000 0x0000000 0x0000000 0x0000000 0x0000000 0x0000000 0x0000000 0x0000000 0x0000000 0x0000000
Channel state: UP Channel IDB: 81ED40EC RX ring entries: 17, buffer size 1548 RX descriptor ring: head = 2903D00, tail = 2903DF0 RX pak ring: head = 81F2A914, tail = 81F2AA04 00 params=0x60C0000 status=0x0 data ptr=0x28ECCC4 next ptr=0x2903D10 01 params=0x60C0000 status=0x0 data ptr=0x28ED344 next ptr=0x2903D20 02 params=0x60C0000 status=0x0 data ptr=0x28EE044 next ptr=0x2903D30 03 params=0x60C0000 status=0x0 data ptr=0x28EED44 next ptr=0x2903D40 04 params=0x60C0000 status=0x0 data ptr=0x28F00C4 next ptr=0x2903D50 05 params=0x60C0000 status=0x0 data ptr=0x28ED9C4 next ptr=0x2903D60 06 params=0x60C0000 status=0x0 data ptr=0x28F1AC4 next ptr=0x2903D70 07 params=0x60C0000 status=0x0 data ptr=0x28F2144 next ptr=0x2903D80 08 params=0x60C0000 status=0x0 data ptr=0x28EFA44 next ptr=0x2903D90 09 params=0x60C0000 status=0x0 data ptr=0x28F3B44 next ptr=0x2903DA0 10 params=0x60C0000 status=0x0 data ptr=0x28EF3C4 next ptr=0x2903DB0 11 params=0x60C0000 status=0x0 data ptr=0x28EE6C4 next ptr=0x2903DC0 12 params=0x60C0000 status=0x0 data ptr=0x28F0744 next ptr=0x2903DD0 13 params=0x60C0000 status=0x0 data ptr=0x28F2E44 next ptr=0x2903DE0 14 params=0x60C0000 status=0x0 data ptr=0x28F27C4 next ptr=0x2903DF0 15 params=0x460C0000 status=0x0 data ptr=0x28F0DC4 next ptr=0x2903E00 16 params=0x60C0000 status=0x0 data ptr=0x28F1444 next ptr=0x2903D00 TX ring entries: 21, in use: 0, buffer size 1548 TX descriptor ring: head = 0, tail = 0 TX pak ring: head = 81DB7F68, tail = 81DB7F68 00 params=0xC0000000 data ptr=0x0000000 next ptr=0x4080E734 01 params=0x0 data ptr=0x0000000 next ptr=0x4080E740 02 params=0x0 data ptr=0x0000000 next ptr=0x4080E74C 03 params=0x0 data ptr=0x0000000 next ptr=0x4080E758 04 params=0x0 data ptr=0x0000000 next ptr=0x4080E764 05 params=0x0 data ptr=0x0000000 next ptr=0x4080E770 06 params=0x0 data ptr=0x0000000 next ptr=0x4080E77C 07 params=0x0 data ptr=0x0000000 next ptr=0x4080E788 08 params=0x0 data ptr=0x0000000 next ptr=0x4080E794 09 params=0x0 data ptr=0x0000000 next ptr=0x4080E7A0 10 params=0x0 data ptr=0x0000000 next ptr=0x4080E7AC 11 params=0x0 data ptr=0x0000000 next ptr=0x4080E7B8 12 params=0x0 data ptr=0x0000000 next ptr=0x4080E7C4 13 params=0x0 data ptr=0x0000000 next ptr=0x4080E7D0 14 params=0x0 data ptr=0x0000000 next ptr=0x4080E7DC 15 params=0x0 data ptr=0x0000000 next ptr=0x4080E7E8 16 params=0x0 data ptr=0x0000000 next ptr=0x4080E7F4 17 params=0x0 data ptr=0x0000000 next ptr=0x4080E800 18 params=0x0 data ptr=0x0000000 next ptr=0x4080E80C 19 params=0x0 data ptr=0x0000000 next ptr=0x4080E818 20 params=0x0 data ptr=0x0000000 next ptr=0x4080E728 List of timeslots (sw): 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 List of all timeslots (hw): 00:00FF00FF 01:00FF00FF 02:00FF00FF 03:00FF00FF 04:00FF00FF 05:00FF00FF 06:00FF00FF 07:00FF00FF 08:00FF00FF 09:00FF00FF 10:00FF00FF 11:00FF00FF 12:00FF00FF 13:00FF00FF 14:00FF00FF 15:00FF00FF 16:00FF00FF 17:00FF00FF 18:00FF00FF 19:00FF00FF 20:00FF00FF 21:00FF00FF 22:00FF00FF 23:00FF00FF 24:20002000 25:20002000 26:20002000 27:20002000 28:20002000 29:20002000 30:20002000 31:20002000 Bandwidth: 1536, idle channel: Unassigned, idle ts bitfield: 0x0 0 missed datagrams, 0 overruns, 0 memory errors 0 transmitter underruns, 0 throttles, 0 enables, 0 bad interrupt elements 0 spurious signaling interrupts
tx_limited=1(2)
