- posted
15 years ago
Cisco 877 - DNS/DHCP/DDNS
- Vote on answer
- posted
15 years ago
Do this: conf t ip ddns update method ddns HTTP add http://[username]:[password]@members.dyndns.org/nic/update?system=dyndns&hostname=&myip=remove http://[username]:[password]@members.dyndns.org/nic/update?system=dyndns&hostname=&myip=interval maximum 28 0 0 0
(but REMEMBER to do Ctrl+v before to type the ? so write all these line manually, don't do a copy/paste.
Then always in conf t type interface Dialer0 ip ddns update hostname [your host].dyndns.org ip ddns update ddns
and substitute [your host].dyndns.org with your host (but use the dyndns.org extensin).
Then if you have an access list for inbound in interface Dialer0 then add this line: access-list 101 permit tcp host 204.13.248.112 eq www any log where 204.13.248.112 is the ip of members.dyndns.org.
Bye
- Vote on answer
- posted
15 years ago
http://[username]:[password]@members.dyndns.org/nic/update?system=dyndns&hostname=&myip=> remove http://[username]:[password]@members.dyndns.org/nic/update?system=dyndns&hostname=&myip=> interval maximum 28 0 0 0
Thanks, but I meant local DNS (e.g. PC gets assignment from DHCP and then the router adds the hostname to DNS.
- Vote on answer
- posted
15 years ago
what a strange things... you could do it with a software on each pc... or better you can assign static ip to each device. Anyway, I don't know how you can do this
