Cisco 2600 + DSL + Cable -> Failover and port forwarding
Threaded View
To whom it shall concern:
I am interested in reconfiguring a Cisco 2600 such that it can perform
failover between a DSL and Cable connection (both have given us static
IP addresses, and neither requires a PPPoE connection).
However, in addition, I have specific port numbers that must be
forwarded to specific IP addresses on the inside network regardless of
if the DSL or the Cable connection is the controlling WAN connection.
Additionally, I would like the Cisco 2600 to be a firewall, and
provision DHCP addresses on the inside network as well.
Does anyone have a recipe for this configuration?
Thanks,
Blake
Re: Cisco 2600 + DSL + Cable -> Failover and port forwarding
you can configure float static route using next comman
ip route x.x.x.x x.x.x.x  x.x.x.x   x
where last X is higher adminstrative distance than the working route
Good luck
Site Timeline
