Cisco Systems Policy Routing: Guaranteeing Bandwidth Question
Subject Author Date
Policy Routing: Guaranteeing Bandwidth Question Mysticmoose06 03-27-07
Posted by Mysticmoose06 on March 27, 2007, 11:23 pm
All,
I work for a school district and we have now outsourced our entire
student information database and with all the internet-traffic we have
on some days, we can easily saturate our T-1 line. (We can easily have
more than 200 concurrent connections, etc.) So I now get angry phone
calls from secretaries who just want to do building attendance but
can't because we're at 98% capacity.
What I would like to do, is set up a policy that takes say 40% of our
bandwidth, and when it is required, is allocated to all traffic going
to our outsourced database ip address. However, when administration /
teachers are not visiting our database site, I want that 40% of the
'reserved' bandwidth to go back into the pot for everyone to use.
Through my research , I believe the solution will come via policy &
class mapping with bandwidth settings. Please review my theory as I am
hoping for comments and improvements.
# Theorized Solution
class-map student-data-traffic
match access-group 171
policy-map student-data
class student-data-traffic
bandwidth percent 40
class class-default
fair-queue
queue-limit 10
Serial 0/0:
ip policy route-map student-data
(create access 171 here)
If there is an easier solution that would offer bandwidth to users
when they need it, and release it when they aren't, I am very open to
ideas.
Thanks in advance for your help.
~ Aaron
Posted by Mysticmoose06 on March 27, 2007, 11:25 pm
> All,
> class class-default
> fair-queue
> queue-limit 10
> Serial 0/0:
> ideas.
> ~ Aaron
Quick Note: Router is a Cisco 2611.
Posted by J.Cottingim on March 28, 2007, 12:02 pm
This looks ok... but...
Be sure that your ACL 171 is configured to PERMIT traffic to the
important web site.
When that when you apply the policy-map to the interface on the 2611,
remember that it's an out-going policy map. Therefore, if the
saturation problem is on the incoming direction, you'll need to do
some tricks to make this work.
To fix this, apply a bandwidth statement and policy-map on your inside
ethernet interface. Assuming you have only one T1 , this would be
(example):
interface ethernet 0/0
bandwidth 1544
service-policy output student-data
Also, you'll need to make sure ACL 171 is built in such a manner as to
be bi-directional.
If the destination web site is 12.13.14.15 then ACL 171 would look
something like this:
access-list 171 remark identify important traffic !<-- always
document your ACL's
access-list 171 remark database site
access-list 171 permit ip any host 12.13.14.15
access-list 171 permit ip host 12.13.14.15 any
With this set up, any traffic that is not identified by ACL 171, would
get the "best effort" treatment.
Also, remember... the traffic exceeds the percentage of bandwidth
you've reserved for any particular class is subject to the "best
effort" treatment.
Alternatively, you could create two separate ACL's with two seperate
policy-maps. This would reduce CPU utilization slightly, and would
increase memory utilization.
Another thing that you could do to *help the situation would be to
further classify traffic. The below example all depends on your
companies' policies on internet usage. Here's the summary:
Class-A
... low-bandwidth high-priority traffic
... (telnet, snmp, snmp-trap, etc)
... guarantee 10% bandwidth
Class-B
... your extremely important traffic (as in ACL 171)
... guarantee 40% bandwidth
Class-C
... your somewhat important traffic (define as necessary)
... guarantee 25% bandwidth
Class-D
... traffic to those Bandwidth Sucking (BS) sites
... ie. youtube, video.google, myspace, etc.
... limit to 128Kb/s
Class-F
... point-to-point file sharing and other unwanted traffic
... drop -or- limit to very small (8Kb/s)
The configuration would look something like this:
class-map match-any CLASS-A
match access-group name Priority-ACL
class-map match-any CLASS-B
match access-group name HIGH-PRIORITY-SITES
class-map match-any CLASS-C
match access-group name MED-PRIORITY-SITES
class-map match-any CLASS-D
match access-group name LOW-PRIORITY-SITES
match protocol http url "*youtube*"
match protocol http url "*video.google*"
match protocol http url "*myspace*"
class-map match-any CLASS-F
match protocol gnutella
match protocol kazaa2
match protocol fasttrack
match protocol napster
match protocol cuseeme
match protocol vdolive
match protocol realaudio
match protocol edonkey
match protocol bittorrent
policy-map QoS-POLICY
class CLASS-A
priority percent 10
class CLASS-B
class CLASS-C
bandwidth percent 25
class CLASS-D
police 128000 1500 1500 conform-action transmit exceed-action drop
class CLASS-F
police 8000 1500 1500 conform-action transmit exceed-action drop
ip access-list extended Priority-ACL
remark Low-bandwidth High-Priority
permit tcp any eq telnet <your-inside-net-address>
permit udp any eq snmp <your-inside-net-address>
permit udp any eq snmptrap <your-inside-net-address>
permit udp any eq tftp <your-inside-net-address>
permit tcp <your-inside-net-address> any eq telnet
permit udp <your-inside-net-address> any eq snmp
permit udp <your-inside-net-address> any eq snmptrap
permit udp <your-inside-net-address> any eq tftp
ip access-list extended HIGH-PRIORITY-SITES
remark Build your ACL 171 here.
ip access-list extended MED-PRIORITY-SITES
remark Build your not-so important traffic acl here
ip access-list extended LOW-PRIORITY-SITES
remark identify any traffic that you want to limit it's speed
You'll need to enable NBAR on the router in order to do the CLASS-F
part. This will add memory and CPU requirements on your router. (it
might be time to upgrade your internet router as well)
Good luck
JC
Posted by Mysticmoose06 on March 28, 2007, 10:04 pm
> important web site.
> (example):
> bandwidth 1544
> be bi-directional.
> document your ACL's
> effort" treatment.
> Class-A
> Class-B
> Class-C
> Class-D
> Class-F
> class CLASS-A
> priority percent 10
> class CLASS-B
> class CLASS-C
> class CLASS-D
> class CLASS-F
> Good luck
> JC
Wow thanks for the detailed response. I essentially just want to give
people bandwidth to the student data when needed and then drop when
not. I'm looking forward to testing this.
Quick question: On our 2611, we have a t-1 card serial 0/0 and an
ethernet. You're saying I have to put the policy map on the ethernet
port? I would assume I have to put it on the serial (i.e. T1)? I'm
little confused on the placement and direction.
Thanks again JC for the help.
Posted by Vincent C Jones on March 29, 2007, 2:56 pm
Mysticmoose06 wrote:
> All,
> class class-default
> fair-queue
> queue-limit 10
> Serial 0/0:
> ideas.
> ~ Aaron
If this is a T1 link to your ISP, you will probably need the ISP to do the
policy routing for you. Unless your traffic patterns are weird for a user
community, you'll find that you T1 is only saturated from the ISP to you,
and still has lots of outbound capacity. Reserving 40% of your outbound
capacity for the data base won't help if YouTube only requires 5% of your
outbound capacity to generate a T3's worth of inbound traffic.
Good luck and have fun!
Vincent C Jones, Consultant Expert advice and a helping hand
Networking Unlimited, Inc. for those who want to manage and
Tenafly, NJ Phone: 201 568-7810 control their networking destiny
http://www.networkingunlimited.com
Similar ThreadsPosted
Policy Routing: Guaranteeing Bandwidth Question March 27, 2007, 11:23 pm
Policy Based Routing Question November 13, 2005, 7:38 pm
policy based routing for multiple tracking options question April 9, 2006, 8:42 pm
Frame-relay bandwidth and policy-maps July 20, 2006, 4:38 am
intervlan routing and policy routing C3750 or C 4948 October 19, 2005, 6:38 pm
GRE & Policy Routing July 28, 2005, 8:46 am
policy routing on PIX October 10, 2008, 9:37 am
PIX 7.0 policy based routing? October 24, 2005, 8:57 am
policy based routing November 4, 2005, 5:14 am
Policy based routing on a ASA February 2, 2007, 5:03 pm
PIX 525, I think I need Policy-based routing?? April 23, 2007, 9:45 pm
Policy based routing April 30, 2008, 11:30 am
Policy Based Routing and/or NAT May 7, 2008, 8:15 am
HSRP and Policy based Routing October 26, 2005, 10:12 pm
Policy Based Routing with 2 providers April 18, 2008, 1:12 am
