Connecting 2 x 2600 routers
Threaded View
I have 2 x 2600 routers. I wish to connect them via direct serial interface
link and use it for testing IP, Frame Relay, x.25 over the link.
I have a crossed serial cable.
What config is needed on each interface to make the link work?
I know that clockrate will need to be set.
Re: Connecting 2 x 2600 routers
Use a DTE-DCE cable. I got mine from http://www.anthonypanda.com /
router A (DTE)
int s0/0
 bandwidth 2048 (optional, needed to give wan utilisation for SNMP reports)
 ip address 10.1.1.1 255.255.255.252
 no shutdown
router B (DCE)
int s0/0
 bandwidth 2048
 ip address 10.1.1.2 255.255.255.252
clock rate 2000000
no shut
This gives an HDLC link with an IP subnet over the WAN.
For Frame Relay, use something like this:
router A (DTE)
frame-relay switching
interface Serial0/0
 bandwidth 512
 no ip address
 encapsulation frame-relay
 no ip route-cache
 no ip mroute-cache
 no fair-queue
interface Serial0/0.1 point-to-point
 bandwidth 256
 ip address 10.1.1.6 255.255.255.252
 no ip route-cache
 no ip mroute-cache
 frame-relay interface-dlci 17 IETF
Router B (DCE)
 bandwidth 512
 no ip address
 no ip route-cache
 no ip mroute-cache
 clockrate 500000
 frame-relay intf-type dce
 bandwidth 256
 ip address 10.1.1.5 255.255.255.252
 no ip route-cache
 no ip mroute-cache
Bob's your uncle.
Big Si (uk)
Cheers Big Si,
I've got the DTE-DCE cable so I will give that config a bash.
Thanks,
Dougie
Just realised I have a smart serial to V35 female -> V35 male to smart
serial.
Will purchase a smart serial to smart serial crossover cable.
Dougie
Site Timeline
