I've just made my first few Cat 5e Ethernet cables and I found the most time consuming/hardest part to be keeping all 8 wires in the right order while inserting them into the RJ45 plug to be crimped.
Is there a tool to make this easier? What I was wishing for was something like a very slim clothespin. Instead of grasping the wires between two of your fingers, you'd grasp the wires between the two sides of the "clothespin." Human fingers are wonderful things, don't get me wrong, but they're not small enough to get inside an RJ45 jack, whereas this "clothespin" would be. That way the wires would stay in the correct order until you got all the way up to the channels in the jack they are threaded into. With that small a distance to go, it is very unlikely that they will become crossed from their order in the pin.
What do you think? Is the idea solid?
