Dear all:
I did a google group search before I post this thread but please bear with me if this had been posted and answered before. I recently wired our house with regular "Category 5e" cable to connect two rooms so that two computers (in different rooms) could share the DSL Internet connection. Here are my questions:
- I assume that most patch cable that you could buy from Radio Shack should be "straight-through" type of cable, am I correct?? In this case to connect the PC to the DSL router, should I use "straight-through" or "cross-over" cable??
- I bought the network plug and the cramping tool (plier) from Radio Shack, and made a the plugs based on "straight-through" cable (following instruction here: formatting linkHowever, after I connect the cable to PC and router, it did not work. If I replace the cable to a shorter (already-made) cable, then the PC would get Internet connect right away. Based on what I see for the working cable, it seems that it is a "straight-through" cable, but I'm not sure, should I actually make the plugs as a "cross-over" type of cable in my case??
- If I do need a cross-over type of cable, as the instruction was not clear on the Web site that I mentioned above, how should I really make the plugs (the color combination/order for both ends)??
- If everything that I did was correct (straight-through cable), could this problem related to the category 5e?? I don't know too much about the 5e standard, but thought that they are downward compatible with category 5... My DSL router is a Buffalo AirStation G54, does this router support 5e cables??
Many thanks!
