I work for a school district that is in the process of bringing on 3 new schools, one of which is a high school with several hundred drops per closet. We use IP telephony and all phones in the district are powered via Power over Ethernet. The issue that we are facing is that due to the cost of PoE switches, we can only afford to put in PoE ports for the number of phones that we have, the rest of the drops connect to non-powered switches. I would like for these closets to have all patch cables neatly arranged and bundled from the panel to the switches running through vertical and horizontal cable managers. The issue we then run into is that once we get a closet all looking good, phones begin to move and cables that were previously plugged into non-powered switches need to be moved to a PoE switch, which requires tracing down a cable through all these bundles of cable management just to move it to the PoE switch.
My initial thought was to just label all of the patch cables as to which drop they connect to on the panel, but with several hundred cables it takes just as long if not longer to find the cable labeled P4 D17 as it does to just trace it down. My other thoughts would be color coding the labels so that a color represents either a certain patch panel or a group of 24 or 48 ports. That way if you knew the cable was on panel 2 (green), then you'd only be looking for green labels to find the right cable.
After thinking about this, I know that several of you already know what works and what doesn't work because you work with this stuff on a daily basis and have seen installations 10x the size of ours. So if any of you have any suggestions as to what works and what doesn't, I'd love to hear it.
Thanks for your help, Matt
