Cable Management Software
May 08, 2006 5 Replies
Jump to replies (5)
Did somebody know a good cable management software (a soft to document cabling/patching in our Datacenter)?
Regards, Marc.
Nobody has a software to document the cabling?
Idea is to document patching and so on in the datacenter. I do not think visio is the right tools?
Anyway, thank you for your answre.
Visionael is good, if your network is big enough to warrant the cost.
Hi Erik,
Thank you for the answer, in the same time i found the product i need. It is itracs.
