Home Automation 3-way motion sensor switch
Subject Author Date
3-way motion sensor switch Nicolas 02-08-07
Posted by Nicolas on February 8, 2007, 11:36 am
I want to install a motion sensor wall plate switch by Cooper or
Leviton. Some of their models can we incorporated in a three way
electrical setup. The other switch would be a standard three way
switch.
I want to know, how all this will work?
I assume if you pass in front of the switch, the lights will go on.
Will it still do that is someone flips the other switch? Will the
motion one be disabled?
If the light is switched on by the manual one, will the lights be
turned off by the motion switch according to it's preset delay?
Regards,
Nicolas
Similar ThreadsPosted
3-way motion sensor switch February 8, 2007, 11:36 am
Motion Sensor, Multi-tone chimes. October 18, 2004, 11:46 pm
control motion/occupancy sensor using PLC [2414U] July 19, 2007, 6:43 am
LEV 6417 motion sensor & LEV HCA02-10E Coupler/Repeater August 3, 2005, 2:53 am
Motion (or Infrared?) detectors for lights or electronics? January 1, 2007, 3:09 pm
X-10 DS10A Door/Window Sensor August 24, 2005, 10:06 am
Directional Driveway Sensor Choices? December 7, 2006, 9:29 am
Wind sensor & Weather Station with display panel or touch screen panel August 23, 2008, 11:22 am
RF light switch September 15, 2005, 2:33 am
gate switch December 10, 2005, 10:59 pm
X-10 Switch Question April 14, 2008, 10:11 pm
X10 switch control logic February 16, 2005, 11:32 am
Beggginer 3-way switch question.... September 22, 2005, 5:33 pm
time delay switch August 18, 2007, 1:34 pm
Is special X10 slave required for 3-way switch? November 10, 2004, 10:49 am
