sticky ip = static ip?
Apr 14, 2005 22 Replies
While that is the general perception, it is partly incorrect. Yes, mostly that is the way that people or companies get their ip address. However, private companies can (and do) own a block of ips. They are free to move them to a different isp. See:
For the most part, these are just being handed out to ISP's today. However, many companies still own their blocks from being assigned them a long time ago. That was the real fear of IPv4 addresses running out. Now, most companies just get their addresses from their upstream provider. While this does provide for extending the life of the IPv4 address scheme, it makes it a royol PITA trying to move your internet services to a different ISP.
That is the very nature of DHCP and has nothing to do with 'sticky'. With DHCP, the address is renewed once half of the lease has expired. This insures that as long as the address is not given up by the client, it will stay the same. Things that can trigger the lease being given up would be the lease expiring (client device turned off for term of lease), DHCP server being rebooted, or in some cases, the client being rebooted. I think sometimes these cable providers flush their DHCP servers and reboot end devices just to force the change and keep people from running home servers. My interpretation of sticky is that an address is married to a device or user independent of the DHCP parameters stated above. As I mentioned in a previous post, I do just that with a Windows VPN. The address is tied to a user, but they don't know the difference since they use DHCP. But, they will get the same address every time. I also have a Netscreen/Juniper VPN device which does the same thing.
Jim
In some cases people also associate "static" vs "dynamic" with how they're assigned. One local ISP assigns all IPs via DHCP, and a lot of people refuse to call those static IPs "static".
Note that DHCP is mandatory with this ISP, if you don't renew your lease then traffic will no longer be routed to your IP.
Some devices will refuse to consider that static as well. IPSEC vpns on some devices won't work with DHCP assigned addresses.
