WPA for Sony Vaio PCG-Z1RMP
Nov 04, 2007 1 Replies
I have a Sony Vaio with Intel Pro/Wireless LAN 2100 3B Mini PCI Adaptor I am unable to connect to networks secured with WPA/WPB Keys. Any help or information with this problem would be most appreciated
Sulumor hath wroth:
  1. Does your Sony Vaio have a model number? Is so, what is it?
  2. Does your Sony Vaio come with an operating system? If so, what is it? If Vista, see:
  3. Out of curiousity, what wireless access point or router are you trying to connect to? If it's yours, has it been upgraded to the latest firmware?
  4. While not directly relevent, I don't like the way some manufacturers have been dragging with Intel Proset updates. The 2100 is an 802.11b only device and has a variety of "issues".
You might consider buying a later device (Intel 2200BG) on eBay.
  1. What's a WPB?
