Antenna pigtail? connector for laptop
Sep 27, 2007 1 Replies
Ok, I'm going to install an Intel Pro/Wireless 2915 80.11abg mPCI adapter into a laptop. The adapter has antenna connectors that are "Hirose U.FL-R-SMT mates with cable connector U.FL-LP-066." Here are some specs for the adapter: 'Intel Pro/Wireless 2915 802.11abg Mini PCI Wireless Network Adapter for For 915G Based Notebooks: WM3B2915ABGNA / WM3B2915AGNAXF (Discontinued)'
I don't know what the connectors inside the laptop are, but I'm attaching an image. (note: it's hard to tell from the image, but the connector is flush with the case...it doesn't stick out at all)
I need two cables, 4-6 inches long each, to connect the wireless adapter to the external antennas on the laptop. (the laptop is actually a tablet, iX104, and I can't find specs on the connectors)
Finding such a cable seems a little harder than it should.
+-------------------------------------------------------------------+ |Filename: DSC_4898.jpg | |Download:
You might want something like this:
is what I'd get, SMA is quite popular with most antennas, very adaptable, and small.
If you don't like that, ere's a list of U.FL pigtails.
They were long addresses, so I shortened it for you. Have fun!
