WiFi bridging reliable solution for business VoIP?
Aug 15, 2006 5 Replies
John Navas
The duplex issue is way overblown IMnsHO -- Wi-Fi latency is quite low (on the order of a millisecond), and unless Wi-Fi speed is very slow (in which case reliability is probably a bigger issue), the fact that only one radio can transmit at a time is pretty much irrelevant…
Hello all,
I am experienced in networking, but new to WiFi and VoIP. In a previous posting about WiFi bridging equipment, someone pointed out that all WiFi technologies are half-duplex and _may_ cause issues with VoIP.
I am researching equipment for a wireless bridge between two buildings and narrowed my choices down to the Proxim Trunami 5054 or the Cisco Aironet 1310G bridges. One pair of these bridges will be dedicated to VoIP traffic, which will have to carry a maximum of 5 simultaneous phone conversations. The lowest aggregate throughput for these solutions is 23 Mbps.
Will the half-duplex nature of WiFi cause quality problems for VoIP? If yes, are there other wireless solutions more appropriate for this setup? Thanks in advance.
Charlie
On 15 Aug 2006 08:58:37 -0700, "Charles Kerekes" wrote in :
The duplex issue is way overblown IMnsHO -- Wi-Fi latency is quite low (on the order of a millisecond), and unless Wi-Fi speed is very slow (in which case reliability is probably a bigger issue), the fact that only one radio can transmit at a time is pretty much irrelevant, since even at only 11 Mbps, each packet takes less than 2 ms of air time. Typical end-to-end latency of a long distance voice call is orders of magnitude higher.
The real issue is QoS (Quality of Service) when a wireless network is under heavy load. Without QoS, there may be annoying pauses due to congestion and packet loss.
If you dedicate a wireless link to VoIP with sufficient capacity to handle worst case traffic then there shouldn't be any significant problems.
The throughput of a standard 802.11g Wi-Fi link will only approach 23 Mbps at maximum 54 Mbps link speed, with requires a strong clear signal, greatly limiting range. As range increases, throughput drops off.
To calculate the necessary bandwidth for VoIP, see . 5 voice circuits typically only need about 0.120 Mbps (120 Kbps), a small fraction of even a slow Wi-Fi link.
Thank you, John--your feedback has been very helpful.
I also spoke to Proxim tech support. According to them, a link carying
5 VoIP lines over a 5054 wireless bridge is a typical setup, and provides good quality phone converstations. I assume this is also true on a similar setup with other products, such as the Cisco wireless bridge.
Charlie
~ Thank you, John--your feedback has been very helpful. ~ ~ I also spoke to Proxim tech support. According to them, a link carying ~ 5 VoIP lines over a 5054 wireless bridge is a typical setup, and ~ provides good quality phone converstations. I assume this is also true ~ on a similar setup with other products, such as the Cisco wireless ~ bridge. ~ ~ Charlie
Yes, we would certainly support 5 G.711 VoIP calls over a 54Mbps point to point link between two BR1310s (assuming good RF.)
In my experience, the main concern would be interference in the 2.4GHz band from other devices in the vicinity.
Regards,
Aaron
Aaron,
Thanks for the reply, Aaron. Since you have a Cisco email address, can I assume that "we" means Cisco?
Charlie
~ > Yes, we would certainly support 5 G.711 VoIP calls over a 54Mbps point to ~ > point link between two BR1310s (assuming good RF.) ~ ~ Thanks for the reply, Aaron. Since you have a Cisco email address, can ~ I assume that "we" means Cisco? ~ ~ Charlie
That would be a reasonable inference.
Aaron
