Where to insert passphrase on Dlink-524
Dec 26, 2004 2 Replies
Airhead
"> I was told I need to insert a long pass phrase but my Dlink, I believe It depends on the model and the firmware your are running. Sounds like your dlink just supports 64bit WEP. A passphrase is just a phrase you type in and it converts it and sticks it in the wep location.…
It depends on the model and the firmware your are running. Sounds like your dlink just supports 64bit WEP. A passphrase is just a phrase you type in and it converts it and sticks it in the wep location. Using the hex is fine. You might check for a firmware update at dlink.
I was told I need to insert a long pass phrase but my Dlink, I believe only allows 10 HEX values. Is there another place I can insert a long pass phrase?
First of all, make sure you update your DI-524 to version 1.05. According to the D-link website, this particular version fixes the WPA passphrase issue. The link is:
Once you've done this, you should be able to select WPA-PSK and enter a long nonsense passphrase up to 63 characters. Let us know how it goes. Take care.
