W98SE and WPA
Feb 01, 2005 2 Replies
The Proxim PCI card (ORiNOCO 11a/b/g PCI Card ) comes with it's own client driver that supports WPA, have a look here
If not, you could check out Funk softwares Odyssey Client, supports
98..
You need what is called a wpa supplicant. Depending on your hardware, the manufacturer of your adapter may have one. Dlink offers AEGIS and I think Linksys uses an Odyssey supplicant and I have heard it works with some other card types using the same chipset. Or there is Funk Software that makes Odyssey, 30 day free trial then 50 bucks.
