Tutorial: How to make a 1-tap shortcut to Samsung Roaming on/off settings when the activity is NOT in the Android settings package
Sep 23, 2023 Last reply: 3 years ago 1 Replies
Moments ago in this thread, TheRealBev discussed "Roaming" settings.
I just made a one-tap shortcut to the Galaxy setting for Roaming=on/off.
Note that this activity is NOT found in the Android settings package! (So you need to know more about the name in order to make a shortcut).
Keeping in mind there are many ways to create a 1-tap shortcut. Each one-tap shortcut may have slightly different circumstances.
Which means you need to be intelligent about creating that shortcut. Here is what I just did to create that one-tap shortcut to roaming.
  1. Use Shortcut Widgets (+ Inspector) by Hamed Nikbakht to find a. unique package name = com.samsung.android.app.telephonyui b. unique activity name = .netsettings.ui.NetSettingsActivity
Note this is a different package than the typical Android settings.
  1. Start App Manager by Muntashir Akon & search for what you found Search for "com.samsung.android.app.telephonyui" & tap the result which brings up the "Call Settings" app to the "App Info" tab.
Tap on the "Activities" tab and scroll down to where you see "Mobile networks" for "com.samsung.android.app.telephonyui".
Then tap on the blue "Create Shortcut" button. Optionally edit the icon image and name as desired. Place onto your homescreen as desired.
Note that the package is colloquially called "Call Settings" (and note that this package may be unique to Samsung devices).
  1. To test, tap on that newly created homescreen shortcut. Voila! This will bring you directly to the roaming on/off activity! com.samsung.android.app.telephonyui.netsettings.ui.NetSettingsActivity
SOFTWARE REQUIRED FOR THIS TUTORIAL: *App Manager* - Android package manager by Muntashir Akon The best full-featured open-source package manager for Android. Free, adfree, gsffree, not available on the Google Play Store repo!
Wally J snipped-for-privacy@invalid.nospam wrote
Another easy way to make a one-tap shortcut to the roaming settings is to create that one-tap shortcut using the FOSS Activity Manager by sdex.
  1. As before, use Shortcut Widgets (+ Inspector) by Hamed Nikbakht to find a. unique package name = com.samsung.android.app.telephonyui b. unique activity name = .netsettings.ui.NetSettingsActivity
Note this is a different package than the typical Android settings. It seems to be a Samsung-specific package outside of Android settings.
  1. Start the "Activity Manager" app, making sure in its settings that "Show system apps" is turned on & then search for keywords (or scroll down to the "Call settings" listing which you learned was where the on/off switch for Roaming was in the prior post.
  2. Press on the sdex FOSS Activity Manager entry for "Call Settings (com.samsung.android.app.telephonyui)" and scroll to the activity previously reported by the Activity Inspector. "NetSettingsActivity Mobile networks (.netsettings.ui.NetSettingsActivity)"
  3. Press the threedots and then "Create shortcut" in the resulting menu. Optionally edit the icon image and name as desired. Place onto your homescreen as desired.
Voila! You've just created a 1-tap shortcut to the roaming = on/off activity.
SOFTWARE: Activity Manager - hidden activity launcher 2.4.1 by sdex (free, adware Activity Manager (former Activity Runner) - hidden activity launcher
Shortcut Widgets (+Inspector) no longer on Google Play Store as of 8/2023)
