Toshiba 9100 Wifi Problem
Jun 30, 2006 7 Replies
Jump to replies (7)
My Toshiba Tecra 9100 does not see my wireless network. The device manager claims that it's working ok, and I've installed the lasted drivers. My network is fine, but when searching it finds nothing, please help.
Cheers
Bryan
On 30 Jun 2006 13:25:29 -0700, snipped-for-privacy@fircroft.net wrote in :
Can it see any wireless networks (anywhere)?
John,
No it see's nothing. Got a d-link pcmcia card in as a temp measure and thats fine, but I want the built in card to work.
Cheers
On 30 Jun 2006 14:10:37 -0700, "Bryan" wrote in :
Sounds like it's not connected to any antennas. You may want to open the machine and check.
can we start again
  1. Did it ever work
  2. Have you added any new security software.
  3. Are your Firewall set to accept other comps including the router in some cases.
On Fri, 30 Jun 2006 23:22:14 GMT, John Navas wrote: : On 30 Jun 2006 14:10:37 -0700, "Bryan" wrote in : : : : >John Navas wrote: : >
: >> On 30 Jun 2006 13:25:29 -0700, snipped-for-privacy@fircroft.net wrote in : >> : : >>
: >> >My Toshiba Tecra 9100 does not see my wireless network. The device : >> >manager claims that it's working ok, and I've installed the lasted : >> >drivers. My network is fine, but when searching it finds nothing, : >> >please help. : >>
: >> Can it see any wireless networks (anywhere)? : : >No it see's nothing. Got a d-link pcmcia card in as a temp measure and : >thats fine, but I want the built in card to work. : : Sounds like it's not connected to any antennas. You may want to open : the machine and check.
Or maybe the radio is turned off. That's almost always an option in the driver. I've also seen at least one laptop with an external switch that the driver couldn't see, which could account for the device manager telling you things are OK.
On Sun, 02 Jul 2006 15:24:15 -0400, Robert Coe wrote in :
Good points. I got bitten recently by such an external switch -- I'd wasted over an hour before it occurred to me to check for one, which made me feel pretty silly.
