Speedbooster - is it on?
Sep 05, 2006 0 Replies
I have recently installed a WRT54GS, and it works great. I have a laptop connected wirelessly to this network, and it has some king of G wifi card built in.
When I check to see the connection speed on the laptop, it usually say 54, occasionally lower, sometimes down to 32 or so.
Do I need to turn "Speedbooster" on, or is it only compatible with other Linksys speedbooster equipment. If so, how do I do it? And what effect can I expect?
I'd really like to be able to move large files quicker between my main PC, connected via NIC to the router, and the laptop.
Thanks in advance
Chris
