:: -------------------------------------------------------------------- :: adbconnect.bat [Connects Android over Wi-Fi without use of USB port] :: :: 1. adbconnect.bat [Primary Daily Driver] :: Use first for routine startup, initial pairing, or port mapping. :: Automatically cleans up stale offline states and maps port 5555. :: :: 2. adbconnecttls.bat [Quick Rescue Safety Net] :: Use when connection drops during the day or adbd goes dormant. :: Bypasses pairing logic, checks mDNS TLS advertiser state, and :: reconnects directly to port 5555 without prompting for codes. :: :: 3. adbdebugtls.bat [Deep Diagnostic Tool] :: Use when both above scripts fail due to Android "Hard Deep Sleep". :: Runs a comprehensive audit of adbd, TCP port 5555, and TLS services :: to diagnose whether a manual phone toggle or reboot is required. :: -------------------------------------------------------------------- :: Android security architecture intentionally imposes hurdles by :: treating persistent wireless debugging ports and dynamic pairing codes :: as security risks, deliberately pushing users toward locked-down :: USB connections or ephemeral sessions (both of which are abhorrent). :: -------------------------------------------------------------------- :: When are Wireless Debugging pairing codes manually required? :: :: 1. After a phone reboot :: Rebooting Android disables Wireless Debugging and clears :: the phone internal cryptographic pairing state. :: :: 2. Corrupted or cleared desktop key cache :: If trusted desktop RSA keys are wiped or modified, :: Android rejects the handshake because unrecognized public :: keys fail verification against the phone authorized list. :: :: When are Wireless Debugging pairing codes automatically bypassed? :: :: 3. Routine Wi-Fi drops and roaming :: If the phone drops packets or roams, port 5555 may close, :: but saved pairing credentials remain intact on both devices. :: :: 4. Android deep sleep error 10061 :: When Android puts adbd to sleep, port 5555 refuses connections. :: Toggling Wireless Debugging off and on on the phone wakes :: the adbd daemon to access port 5555 without pairing codes. :: -------------------------------------------------------------------- :: Automate Android-to-desktop Wi-Fi adb and scrcpy [mirroring] :: a. ADB provides complete control of the phone from the desktop :: b. Over USB or Wi-Fi [I exclusively used Wi-Fi in all my testing] :: c. Mirroring the phone [scrcpy] so that the desktop controls it :: i. The desktop monitor displays the phone :: ii. The desktop speakers output the phone audio :: iii. The desktop keyboard types into the phone's keyboard input :: iv. The desktop mouse taps on the mirror to operate the phone :: v. The desktop clipboard works seamlessly with the phone keyboard :: vi. The desktop screen copying and editing tools work perfectly :: vii. All sans any need for the net or a privacy-robbing account :: ------------------------------------------------------------------------ :: adbconnect.bat is intended for daily startup or when pairing a fresh :: debug port/connection after a phone reboot. :: adbconnecttls.bat: is intended for quick reconnections when the :: connection drops during the day or when waking adbd from deep sleep. :: ------------------------------------------------------------------------ :: Key Design & Automation Features: :: :: 1. Stale State Cleanup :: Automatically detects and clears stale offline or unauthorized :: device states, preventing unnecessary Wi-Fi pairing prompts. :: :: 2. Fast Reconnects :: Attempts a direct reconnect to port 5555 upon network drops :: before falling back to the full pairing workflow. :: :: 3. Persistent Binding :: Forces 'tcpip 5555' to keep the adbd daemon active and listening :: on the network until the phone is rebooted. :: :: 4. Silent Execution :: Uses a VBS helper script to launch scrcpy seamlessly without :: leaving an annoying command console window open. :: ------------------------------------------------------------------------ :: v3p5 20261106 :: Added a hail-mary play to remotely toggle wi-fi debugging under the :: strict conditions when adbd on the phone is still listening and is :: still reachable over the network, for example, when port 5555 is bound, :: or when the debug daemon is alive but just needs a software restart. :: :: v3p4 20261106 :: Updated device-checking logic to disconnect and purge stale offline :: or unauthorized device states, to prevent spurious pairing prompts :: :: v3p3 20261030 :: Removed parenthesis in :: lines & added minor comments :: :: v3p2 20260901 :: Modified scrcpy options to allow dual playback on both PC and phone :: scrcpy --audio-source=playback --audio-dup :: Note: Requires scrcpy 3+ and Android 11+ :: :: v3p1 20260829 :: Added a section comparing adbconnect.bat to adbconnecttls.bat :: :: v3p0 20260829 :: Added fast-reconnect fallback before prompting for pairing codes :: Being disconnected is not the same as being unpaired but because :: adbconnect.bat lumps them together, it forces us down the full :: pairing workflow [adb pair] unnecessarily. Let's fix that. :: adbconnect.bat shouldn't jump straight to asking for a pairing code :: when it fails to find the device. Instead, when it sees the device :: is missing, it should first try a simple adb connect %PHONE_IP%:5555 :: using existing credentials. Only if that fails should it drop down :: to asking for a new pairing code. :: :: v2p9 20260829 :: Disabled mDNS auto-connect to prevent multi-device TLS ghost issue :: C:\> adb devices :: List of devices attached :: 192.168.1.4:5555 device :: adb-ABCDEFG1234-ABCDEF._adb-tls-connect._tcp device :: set ADB_MDNS_AUTO_CONNECT=0 :: :: v2p8 20260809 :: Improved comments for general use by others on any desktop platform :: :: v2p7 20260807 :: Added a disconnect for the old debug port right after :: adb connect %PHONE_IP%:5555, using the DEBUG_PORT captured :: :: v2p6 20260730 :: Added detailed overview in the comments section for easy re-use :: :: v2p5 20260630 :: Cleaned up the descriptions by summarizing the version comments. :: :: v2p4 20260630 :: Added version output string and improved explanations :: :: v2p3 20260624 :: Added ability to detect if USB authentication was already done :: :: v2p2 20260622 :: Improved handling of offline and unauthorized states :: :: v2p1 20260621 :: Added SUMMARY system for executed commands :: :: v2p0 20260621 :: Restored working version from v1p7 :: :: v1p9 20260620 :: Removed debug-port connect step which broke Wireless Debugging :: :: v1p8 20260619 :: Removed debug-port connect step which broke Wireless Debugging :: :: v1p7 20260615 :: Removed requirement for scrcpy-noconsole.vbs :: :: v1p6 20260614 :: Added VBS no-console launcher fallback :: :: v1p5 20260613 :: Added query asking for phone LAN IP address :: :: v1p4 20260612 :: Eliminated need for scrcpy console window [using no-console vbs] :: :: v1p3 20260612 :: Improved reliability of adb devices parsing :: :: v1p2 20260611 :: Added retry logic and improved device-id handling :: :: v1p1 20260611 :: Improved device lookup and reliability :: :: v1p0 20260611 :: Converted adbconnect.vbs from Genymotion scrcpy to adbconnect.bat :: Mirrors phone onto desktop over Wi-Fi [or USB] using adb and scrcpy :: -------------------------------------------------------------------- :: Connects Android 11 and Android 12+ devices to adb and scrcpy using :: pairing mode and classic TCPIP mode. This script uses the Android :: Wireless Debugging pairing workflow to obtain the pairing port, :: pairing code and debug port from the phone. It then performs adb :: pair and adb connect with retry logic, switches the device to TCPIP :: port 5555 and launches scrcpy silently. This script does not use TLS :: for the scrcpy connection, but it depends on Wireless Debugging :: being active because Wireless Debugging controls whether adbd is :: reachable. Once TCPIP mode is enabled, the script reconnects to :: port 5555 and starts scrcpy over classic TCPIP mode. :: :: 1. Eliminates the useless scrcpy console window which takes up space :: 2. Eliminates random security steps in Wi-Fi adb connections :: 3. Solves reconnection problems when :: a. The phone leaves the LAN and returns :: b. The PC is rebooted :: c. The phone is rebooted :: d. A connection is attempted when already connected :: Uses Wireless Debugging mode plus classic TCPIP ADB mode. :: Wireless Debugging does not open port 5555 by itself. :: Classic ADB-over-WiFi can use port 5555 to simplify reconnects. :: Running adb tcpip 5555 forces Android to open port 5555 even in :: Wireless Debugging mode. This makes reconnections simpler because :: the phone stays open on port 5555 even if :: a. the phone leaves and rejoins the LAN :: b. the PC reboots :: c. scrcpy drops and reconnects :: Port 5555 remains active until the phone reboots because Android :: rebooting disables Wireless Debugging and closes the TCPIP daemon. :: :: USB authorization can eliminate pairing codes :: i. Connect via USB :: ii. adb connect PHONE_IP:5555 :: iii. scrcpy --tcpip=PHONE_IP :: :: If a USB device is present and authorized, adb devices will show :: PHONE_IP:5555 device :: You cannot get device state without USB authorization :: :: Android 12+ introduced ADB-over-TLS auto-advertised via mDNS. :: It auto-connects over encrypted channels without pairing or ports. :: It appears as adb-SERIAL-GUID._adb-tls-connect._tcp :: Wireless Debugging controls whether this TLS service is awake. :: scrcpy cannot use the TLS auto-connect device directly. :: :: This script uses pairing mode and TCPIP mode only. :: TLS auto-connect is not used for scrcpy, but TLS must be awake :: for adbd to be reachable. :: :: This design removes all typical friction points: :: a. No USB cable :: b. No scrcpy console window :: c. No repeated pairing :: d. No manual port switching :: e. No manual IP entry [if static] :: f. No TLS scrcpy complications :: g. No adb-offline / unauthorized headaches :: :: There's the following in the script below: :: A. Reliable adb discovery :: a. finding adb across $PATH :: b. And forcing the exe to ensure reliability :: B. Reliable device-state detection :: a. Handling pairing failures :: b. retry timing :: c. debug-port connection :: d. fallback device-ID detection :: C. TCPIP mode forcing :: a. Which exploits adb tcpip 5555 classic TCPIP mode :: b. Such that the port stays open until the phone reboots :: c. Which is the key to making reconnection trivial. :: D. Silent scrcpy launch :: a. exploiting vbs capabilities :: b. For a no-console hassle-free experience :: E. Summary logging :: a. By appending only successful commands :: b. Which is useful for debugging intermittent Wireless Debugging behavior :: F. LAN-wide complete control :: a. Becuse it uses a static IP :: b. and a forced TCPIP mode with scrcpy over 5555 :: c. We can operate the phone even if: :: i. it's asleep :: ii. it's locked :: iii. it's physically inaccessible :: G. Automatic recovery :: a. The script handles the phone leaving/rejoining LAN :: b. and/or a PC reboot :: c. and/or a phone reboot :: d. and/or a scrcpy reconnect :: e. and various adb offline states :: :: This is extremely powerful, as, for example, if you're at your desktop :: and you need to text someone from a phone on the LAN, it's easy to do. :: :: Of course there's always more to add, such as: :: 1. adding auto-IP discovery via ARP scan :: 2. adding auto-TLS detection for Android 12+ :: 3. adding an auto-reconnect daemon :: 4. adding scrcpy overlay controls :: 5. adding phone battery/temperature polling :: 6. adding multi-device support :: 7. adding LAN broadcast discovery :: -------------------------------------------------------------------- :: To integrate this script into a Windows quick-reaction command... :: 1. Test that your command is not yet known to Windows' special paths. :: Win+R > mirror :: You should see "Windows cannot find mirror..." :: NB: I don't use Win+R because I have a runbox pinned to the taskbar. :: :: 2. Create a shortcut that calls the batch file that does all the work. :: C:\path-to\lnk\mirror.lnk :: target=%comspec% /k cd C:\path-to\bat & C:\path-to\bat\adbconnect.bat :: :: 3. Add a registry key, making sure to name the key with an 'exe' extension. :: HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\mirror.exe :: Default=C:\path-to\lnk\mirror.lnk :: NB : The destination must exist for this quick reaction key to work. :: :: 4. Test that your quick-reaction command is working to mirror Android. :: Win+R > mirror :: :: What should happen is: :: a. The runbox command finds "mirror.exe" in the App Paths key :: b. Which finds mirror.lnk in your shortcuts folder :: c. Which runs adbconnect.bat in your batch folder :: :: Note that this design makes use of App Paths as an instant global command :: a. App Paths works with shortcuts, not just executables :: b. It works with Win+R, Start menu search, and Explorer :: c. It allows naming the command anything [mirror.exe -> adbconnect.bat] :: d. It avoids $PATH pollution :: e. It eliminates %PATH duplication mistakes :: -------------------------------------------------------------------- :: Comparison of adbconnect.bat vs adbconnecttls.bat :: :: adbconnect.bat [initial heavy hitter] :: a. Designed for everyday automation, pairing and TCPIP port mapping :: b. First uses a dynamic Wireless Debugging debug port to initialize :: c. Then forces a classic TCP/IP port 5555 connection, for persistence :: d. Includes a full pairing workflow fallback [pair port, pairing code] :: e. Features fast-reconnect logic to prevent false pairing prompts :: :: adbconnecttls.bat [later rescue, if needed] :: a. Designed as a safety net when the primary adbconnect.bat fails :: b. Has no pairing logic [assumes cryptographic keys are already trusted] :: c. Connects directly to port 5555 without touching debug ports :: e. Focuses on mDNS TLS advertiser checks to detect "ADB Deep Sleep" :: f. Instructs the user on physical actions instead of asking for codes :: :: Why the tag team of adbconnect.bat and then adbconnecttls [if needed]? :: a. adbconnect.bat handles routine connections and setup seamlessly :: b. But if the flaky Android adbd daemon locks up or goes dormant... :: c. Then adbconnecttls.bat diagnoses the sleep state and resets the :: server cleanly without disrupting saved pairing keys. :: -------------------------------------------------------------------- :: Tested on the following Windows, Android, adb and scrcpy versions :: C:\> ver :: Microsoft Windows [Version 10.0.19045.6466] :: C:\> adb shell getprop ro.build.version.sdk :: 33 :: Note: API 33 is Android 13 :: C:\> adb --version :: Android Debug Bridge version 1.0.41 :: Version 35.0.2-12147458 :: Installed as C:\app\editor\android\scrcpy\adb.exe :: Running on Windows 10.0.19045 :: C:\> scrcpy --version :: scrcpy 3.0
:: Dependencies [compiled
/ linked]: :: - SDL: 2.30.9 / 2.30.9 :: - libavcodec: 61.19.100
/ 61.19.100 :: - libavformat: 61.7.100 / 61.7.100 :: - libavutil: 59.39.100
/ 59.39.100 :: - libusb: - / 1.0.27 :: -------------------------------------------------------------------- @echo off :: vi. debugging can be removed later :: echo MARK 1 setlocal enabledelayedexpansion :: Disable automatic TLS ghost connections set ADB_MDNS_AUTO_CONNECT=0 :: Version string set SCRIPT_VERSION=v3p5 set SCRIPT_DATE=20261106 echo ============================================ echo ADB-over-TLS to TCPIP Launcher Debug Mode echo Running adbconnect.bat %SCRIPT_VERSION% %SCRIPT_DATE% echo ============================================ echo. :: initialize temp summary file set SUMMARY_FILE=%TEMP%\adbconnect_summary.txt if exist "%SUMMARY_FILE%" del "%SUMMARY_FILE%" :: On phones with static IP addresses, change the next line set PHONE_IP=192.168.1.4 :: set SCRCPY_OPTS=--keyboard=sdk --always-on-top :: For whatever reason, "--keyboard=sd" makes Termux not accept Ctrl+V paste :: set SCRCPY_OPTS=--keyboard=sdk :: For whatever reason, "--legacy-paste" allows Termux to accept Ctrl+V paste :: Allows dual playback: scrcpy --audio-source=playback --audio-dup :: set SCRCPY_OPTS=--legacy-paste set SCRCPY_OPTS=--legacy-paste --audio-source=playback --audio-dup echo. echo === ADB Wireless Auto-Connect === echo === [Developer options > Wireless debugging > on] === echo. REM 1. Find adb :: REM ii. debugging [can be removed later] :: if defined TRACE echo BEFORE FIRST FOR :: REM vii. debugging can be removed later :: echo MARK 2 for /f "delims=" %%A in ('where adb 2^>nul') do ( if not defined ADB set ADB=%%A ) :: REM viii. debugging can be removed later :: echo MARK 3 :: REM iii. debugging [can be removed later] :: if defined TRACE echo AFTER FIRST FOR if not defined ADB ( echo [ERROR] adb.exe not found. exit /b ) REM Ensure .exe extension if /i not "%ADB:~-4%"==".exe" set ADB=%ADB%.exe echo Using ADB: "%ADB%" echo. REM 2. Check if already connected echo Checking existing ADB devices... :: REM i. debugging [can be removed later] :: set TRACE=1 set DEVICE_ID= set DEVICE_STATE= REM Do not add extra quotes here as all these break batch parsing! :: '"%ADB%" devices' :: "%ADB%" devices :: '"%ADB%" devices"' :: '"%ADB%" devices"' :: REM iv. debugging can be removed later :: if defined TRACE echo BEFORE SECOND FOR :: REM ix. debugging can be removed later :: echo MARK 4 for /f "skip=1 tokens=1,2" %%I in ('%ADB% devices') do ( echo %%I | findstr /I "%PHONE_IP%" >nul && ( if not defined DEVICE_ID ( set DEVICE_ID=%%I set DEVICE_STATE=%%J ) ) ) :: REM x. debugging can be removed later :: echo MARK 5 :: REM v. debugging can be removed later :: if defined TRACE echo AFTER SECOND FOR REM treat only "device" as connected :: echo MARK 6 echo DEVICE_ID="%DEVICE_ID%" DEVICE_STATE="%DEVICE_STATE%" REM if no device id, try a quick reconnect before giving up and pairing if "%DEVICE_ID%"=="" goto TRY_RECONNECT REM if state is offline or unauthorized, purge it and try reconnecting instead of pairing if /I "%DEVICE_STATE%"=="offline" ( "%ADB%" disconnect "%DEVICE_ID%" >nul 2>&1 set DEVICE_ID= set DEVICE_STATE= goto TRY_RECONNECT ) if /I "%DEVICE_STATE%"=="unauthorized" ( "%ADB%" disconnect "%DEVICE_ID%" >nul 2>&1 set DEVICE_ID= set DEVICE_STATE= goto TRY_RECONNECT ) REM if state is not "device", skip to NOT_CONNECTED if /I not "%DEVICE_STATE%"=="device" goto NOT_CONNECTED echo Already connected on %DEVICE_ID% echo adb devices>>"%SUMMARY_FILE%" REM skip redundant tcpip if already on 5555 if /I "%DEVICE_ID:~-5%"==":5555" ( echo Device already on port 5555. Skipping tcpip switch. goto RUN_SCRCPY ) goto RUN_TCPIP :TRY_RECONNECT echo Device not found in active list. Attempting fast reconnect to %PHONE_IP%:5555... "%ADB%" connect %PHONE_IP%:5555 >nul 2>&1 :: Check if the fast reconnect worked set DEVICE_ID= for /f "tokens=1" %%I in ('%ADB% devices ^| findstr /C:"%PHONE_IP%:"') do ( if not defined DEVICE_ID set DEVICE_ID=%%I ) if defined DEVICE_ID ( echo Fast reconnect successful! echo adb connect %PHONE_IP%:5555>>"%SUMMARY_FILE%" goto RUN_TCPIP ) :: If connection refused or failed, bounce the local adb server and retry once echo Fast reconnect failed. Resetting local adb server daemon... "%ADB%" kill-server >nul 2>&1 timeout /t 1 >nul "%ADB%" start-server >nul 2>&1 echo Retrying connection to %PHONE_IP%:5555 after server reset... "%ADB%" connect %PHONE_IP%:5555 >nul 2>&1 set DEVICE_ID= for /f "tokens=1" %%I in ('%ADB% devices ^| findstr
/C:"%PHONE_IP%:"') do ( if not defined DEVICE_ID set DEVICE_ID=%%I ) if defined DEVICE_ID ( echo Reconnect successful after adb server reset! echo adb kill-server / start-server / adb connect %PHONE_IP%:5555>>"%SUMMARY_FILE%" goto RUN_TCPIP ) echo Fast reconnect and server reset failed. Falling back to full pairing workflow... echo. :NOT_CONNECTED :: echo MARK 8 echo Not connected. Need to pair. echo. REM 3. Ask user for pairing info echo Necessary pairing information will be shown on the phone: set /p PHONE_IP=Phone IP [%PHONE_IP%] : set /p PAIR_PORT=Wireless debugging pairing port: set /p PAIR_CODE=Wireless debugging pairing code: set /p DEBUG_PORT=Wireless debugging debug port: echo. echo Pairing with: %PHONE_IP%:%PAIR_PORT% REM Retry logic for adb pair (3 attempts) set ATTEMPTS_PAIR=0 :PAIR_RETRY set /a ATTEMPTS_PAIR+=1 "%ADB%" pair %PHONE_IP%:%PAIR_PORT% %PAIR_CODE% if not errorlevel 1 ( echo adb pair %PHONE_IP%:%PAIR_PORT% %PAIR_CODE%>>"%SUMMARY_FILE%" ) if errorlevel 1 ( if !ATTEMPTS_PAIR! lss 3 ( echo Pair failed, retrying... timeout /t 2 >nul goto PAIR_RETRY ) else ( echo [ERROR] adb pair failed after %ATTEMPTS_PAIR% attempts. exit /b 1 ) ) echo. echo Connecting to debug port: %PHONE_IP%:%DEBUG_PORT% REM Retry logic for adb connect (3 attempts) set ATTEMPTS_CONN=0 :CONNECT_RETRY set /a ATTEMPTS_CONN+=1 "%ADB%" connect %PHONE_IP%:%DEBUG_PORT% if not errorlevel 1 ( echo adb connect %PHONE_IP%:%DEBUG_PORT%>>"%SUMMARY_FILE%" ) REM wait a few seconds for the Android adb daemon to be ready timeout /t 2 >nul if errorlevel 1 ( if !ATTEMPTS_CONN! lss 3 ( echo Connect failed, retrying... timeout /t 2 >nul goto CONNECT_RETRY ) else ( echo [ERROR] adb connect %PHONE_IP%:%DEBUG_PORT% failed after %ATTEMPTS_CONN% attempts. exit /b 2 ) ) echo. REM Do not add extra quotes here as all these break batch parsing! :: '"%ADB%" devices' :: "%ADB%" devices :: '"%ADB%" devices"' :: '"%ADB%" devices"' REM After connect, get the actual device id set DEVICE_ID= for /f "tokens=1" %%I in ('%ADB% devices ^| findstr /C:"%PHONE_IP%:"') do ( if not defined DEVICE_ID set DEVICE_ID=%%I ) if defined DEVICE_ID ( echo Found device id: "%DEVICE_ID%" ) else ( echo [WARN] No device id found after connect. set DEVICE_ID=%PHONE_IP%:%DEBUG_PORT% ) goto RUN_TCPIP :RUN_TCPIP echo Switching device %DEVICE_ID% to TCP/IP 5555... "%ADB%" -s "%DEVICE_ID%" tcpip 5555 if not errorlevel 1 echo adb -s %DEVICE_ID% tcpip 5555>>"%SUMMARY_FILE%" echo Connecting final port: %PHONE_IP%:5555 "%ADB%" connect %PHONE_IP%:5555 if not errorlevel 1 echo adb connect %PHONE_IP%:5555>>"%SUMMARY_FILE%" echo Disconnecting stale debug port: %PHONE_IP%:%DEBUG_PORT% "%ADB%" disconnect %PHONE_IP%:%DEBUG_PORT% >nul 2>&1 if not errorlevel 1 echo adb disconnect %PHONE_IP%:%DEBUG_PORT%>>"%SUMMARY_FILE%" set DEVICE_ID=%PHONE_IP%:5555 :RUN_SCRCPY echo Launching scrcpy completely silent... set "VBS_TEMP=%TEMP%\scrcpy_runner.vbs" echo strCommand = "cmd /c scrcpy.exe --tcpip=%PHONE_IP% %SCRCPY_OPTS%" > "%VBS_TEMP%" echo CreateObject("Wscript.Shell").Run strCommand, 0, false >> "%VBS_TEMP%" echo scrcpy --tcpip=%PHONE_IP% %SCRCPY_OPTS%>>"%SUMMARY_FILE%" wscript.exe "%VBS_TEMP%" timeout /t 1 >nul if exist "%VBS_TEMP%" del "%VBS_TEMP%" echo Done. echo. echo Summary of steps run in this instance: type "%SUMMARY_FILE%" echo. echo. echo. exit /b REM end of adbconnect.bat
