Does Windows perform randomized SCANS when searching for Wi-Fi/Bluetooth Access Points?
Mar 07, 2023 Last reply: 3 years ago 6 Replies
Brian Gregory
My Android mobile phone now defaults to some kind of MAC randomization. It's damn annoying. If I forget of disable it none of the public Wi-Fi access points I use will let me use them without re-registering every time. I don't fully understand what it's doing though, because my…
For Bluetooth and/or Wi-Fi, does Windows have the capability for...
  1. MAC randomization *when scanning*
  2. MAC randomization *per access point*
  3. MAC randomization *per connection*
  4. Did I miss any critical timer periods?
BACKGROUND:
The motherships (Apple & Google & Samsung at least) are starting to be aware of the privacy flaws inherent in having a permanent MAC address.
So they're sloooooooooowly providing, release by release, the inherent capability to randomize your MAC address during those three tasks.
This article back in 2014, shows the danger of NOT randomizing Wi-Fi: "When scanning for wireless networks, client devices like the iPhone periodically broadcast identifying packets that include the MAC address. In recent years, a number of firms have taken advantage of these broadcasts to track individual devices as they move around - for example, some retail outlets use MAC address-based tracking to record the path that consumers take as they move through the store, allowing long-term measurement of shopping habits and better placement of sale materials and advertising."
And, this line in that same article shows the dangers with Bluetooth: "The city of Houston's TranStar traffic monitoring system, for instance, uses the MAC addresses from Bluetooth devices to measure traffic flow on city streets."
The question I'm asking for this Windows newsgroup is whether Microsoft has added this capability to randomize the Bluetooth & Wi-Fi MAC during 3 times a. When scanning b. When connecting (per access point) c. When connecting (per connection)
An example of these types of settings on other platforms might be this:
Random MAC on every connect
Although it has implications for your home router LAN setup for static IPs.
Static/Reserved IP address
My Android mobile phone now defaults to some kind of MAC randomization. It's damn annoying. If I forget of disable it none of the public Wi-Fi access points I use will let me use them without re-registering every time. I don't fully understand what it's doing though, because my own home Wi-Fi manages to give it the same IP address every time.
Brian Gregory used his or her keyboard to write :
The phone should remember per-SSID which random MAC it previously used (or whether it used its hardware MAC) are you telling it to forget the SSIDs after you use them ... some earlier firmware *did* use random every time and they stopped for the reason you describe.
Is "scanning" a listen-only activity?
This specific answer above is better discussed on the Android newsgroup, but the latest Android versions do _both_ (it's two separate settings).
  1. By default, the MAC is randomized _per SSID_ (probably per BSSID)
  2. In Developer options, you can set randomization per connection.
    Random on every connect
I'm not sure what MAC Windows uses for _scanning_ though. *Which is why this thread was opened to find out.*
There are multiple scenarios to consider for the scanning question.
  1. scanning for known ssids that are hidden
  2. scanning for known ssids that are not hidden
  3. scanning for unknown ssids that are not hidden
  4. any others?
How does Windows handle the randomization when scanning? (Note: How Apple does it for iOS is referenced in the sig.)
I get where you're coming from, which is that passive listening shouldn't be a privacy problem but there's got to be a privacy issue to be resolved (whether or not Windows resolves it) because _both_ Apple (for iOS) and Google (for Android) implemented randomized randomization (AFAIK).
I just don't know what Windows does when scanning for hidden access points.
Here's a link for Apple's implementation of randomizing MACs for scans.
I also know what Android uses for _connecting_ to a Wi-Fi access point.
But I am not quite sure what Wi-Fi MAC address is used while _scanning_ for Wi-Fi (or Bluetooth) access points (or for _connecting_ to Bluetooth APs.)
But that's only background because the question here is what Windows randomizes when Windows actively scans (probes?) for Wi-Fi access points.
Specifically hidden access points. If I knew how Windows handles these scenarios, I wouldn't be asking. :)
Some scenarios I can think of where Windows might randomize might be: a. When scanning for hidden access points Windows is aware of b. When scanning for not hidden access points Windows is aware of c. When scanning for access points that are not hidden d. Any others?
Note: Scanning may be tantamount to probing (but I'm not sure so I added the wireless folks who can clarify if scanning is different from probing).
