Newbie question: how do I get my VOIP phone and Xbox console....
Jan 05, 2005 0 Replies
to work with my wireless router, the Linksys WRT54G ? I have opened a DMZ for the Xbox console to work on Xbox live, and it appears the VOIP phone (Vonage) is working so far, even with WPA encryption. The phone plugs into a wired router which then plugs into the wireless router. Long story. Should I just leave it alone ? Thanks in advance. Steve
