lost wep key how do i get connected now??
Oct 17, 2007 3 Replies
Spock ‹(=E
In message , bommer88 writes Download this program wirelesskeyview and run it on your pc with the key installed:- can recover the key and use it on the laptop.
hey i set my pc up for wireless to a bt home hub and used a wep key now i would like to do same to my laptop but ive lost my booklet with wep key etc what can i do to retrive it? its still on my pc but its like this ***** so ita a problem to find out any help appreciated
The easy way to do that is to setup a new key at the router.
You can recover the key and use it on the laptop.
If you look at the back of the HomeHub there is a label. Read the Wireless Key followed by ten alphanumeric digits.
Josef
