Linksys WRT55AG caught in constant reboot cycle
Dec 26, 2009 2 Replies
My WRT55AG started acting up a day ago. It apparently boots, stays stable for about a second, then repeatedly reboots. I bought it in 2004, so it's
5+ years old. I remember that the warranty period was only 3 years. I've tried resetting it and also managed to get it stable enough to do a factory reset - but it returns to constantly rebooting. Is it probably hosed?
I had done no modifications to it. It's running Linksys's firmware v1.70.
Hi, Make sure your Wall wart is still in good order. If you have another one try it.
So, you think it may be a power supply problem? I'll check that.
