linksys wmp54g vista problems
Feb 18, 2007 4 Replies
Most relevant reply
Kev
Have you tried using your XP drivers?
Hi
Anybody got a linksys wmp54g v2(with the broadcom chipset) wireless network card to work with Vista x64.
It seems to install ok, but the onnection is very intermittent, it keep diisconnecting every few minutes or so
It isn't on the list to be supported.
I wondered if that was the reason
It does seem to install properly though - i.e. it picks up the broadcom drivers supplied with Vista and in device manager it says there are no problems with the device
I think that has worked
Replaced the default windows supplied driver with that off the linksys website, and am not gettting any more disconnections. I suspect it was due to fluctuations in the quality of the wireless connection between the wireless network card and the router.
