Linksys router - high freq sizzle/crackle
Jun 22, 2010 2 Replies
I have a Linksys BEFSX41 router -
Recently it has developed an ailment like an old TV set. You can hear a high frequency sizzle-crackle like sound.
I don't think there is anything like a flyback transformer, but what could be causing this same type of sound ?
If I break the seal & crack it open - what area should I look at ?
Before pulling your hair out, see if you've got a replacement "wallwart" you can use to power it up.
It's not likely to be a power issue, but it's simple enough to check out.
