Is it normal to lose 15 dB @ 2.4Ghz through double-pane window glass?
Mar 24, 2012 21 Replies
See section 1.2: "A similar cage was constructed as a control, with fiberglass screen, which is not conductive and which does not block RF signals, instead of aluminum."
Wow, that is tin foil hat territory. [Yes, I know the foil isn't tin anymore.] However, the Faraday cage test is probaly OK.
I have some near IR CCDs (response to 1um) and R72 filters. Looking at black stuff, you find black often isn't black under IR. Some black is completely transparent to IR, so I have to presume there are different ways to produce black items. Maybe the black that isn't transparent to IR has carbon in it.
According to this wiki (gasp), carbon black absorbs IR:
