Intelligent Gateway 1800 Flash upgrade
Apr 16, 2005 4 Replies
Jump to replies (4)
Just purchased one of these and it turns out that the software that resides in the flash is corrupted.
Does anyone know where I can get the flash program and the .ROM file to reflash the software?
There is nothing on 2wire.com site.
Cheers
The message that I am getting is :
The installed version of Intelligent Gateway 1800 software is no longer functioning properly. This can result from a failed software upgrade or other memory corruption. Please contact technical support for assistance
The message your getting is from the homeportal monitor which lies(alot) it was probably blocked by a firewall and does not see the homeportal
the only time you need to flash the firmware is if the lights on the front are as below
Power = RED Broadband = Red LAN = Green
if these conditions dont apply its not a firmware issue its probably a
3rd party conflict Call 2wire tech support or the person who sold you the home portal they will be able to help you fix it
In message , Aosmosis writes
Any use?
yup thats the same sequence that I have.
How the hell can i flash the firmware, without sending it to the US.
BT have said that they dont want anything to do with it.
