Min recommended flash in upgrade planner
Mar 01, 2007 2 Replies
I have a 837 with 12MB of flash and 64MB ram. I looked today at the upgrade planner, and in the upgrade for 12.4.13, it said the minimum recommended flash was 16MB, even though the file was just over 9MB (actually just a few K larger than the 12.4.12A release, which gives
12MB as minimum flash).
Is this requirement in case you have some type of management app installed in with the IOS (like the SDM program, which we don't use), or am I stuck on 12.4.12A? Is it worth replacing the flash chips in a router that is around 3 years old?
Thanks. Andrew.
Yes.
As long as the image fits, the router will boot and operate normally.
Thanks. Running on 12.4.13 now.
Andrew.
