Installation software for Lucient/Orinoco Silver PCMCIA card
Aug 17, 2006 4 Replies
Jump to replies (4)
I've lost the installation software for my Orinoco "Silver" PCMCIA card. The card also has the name Lucient Technologies on it. Can anyone help me find the software? A message to snipped-for-privacy@orinocowireless.com bounced. Would appreciate a direct reply to snipped-for-privacy@mcn.org. Thanks.
[posted and mailed]
snipped-for-privacy@mcn.org (Rob) wrote in news:1155824357.964711.119830 @m79g2000cwm.googlegroups.com:
Orinoco branded products are now sold by Proxim.
I also think that Window's xp supports those cards, just plug it in and see if it auto detects, or run windows update with the card installed see what happens. You might want to consider an upgrade as those cards only support 64 bit wep, and as cheap as cards are now it shouldn't cost you much for a good wpa card.
Rthoreau
Hi ..
Little googling returned the link below:
-aljuhani
The latest drivers/firmware update for those cards support WPA TKIP.
