how to limit the selection of available networks
Oct 02, 2007 1 Replies
dualdflipflop
Not that I know of. The preferred network option is the only real way. It's a radio transmission, if the adapter picks up the signal, the software is designed only to report it. The best you could do on Windows is what you just did as far as I know.
Using WinXP.... is there any way to limit (or filter) the list of available wireless networks that my adapter finds? I already have the "automatically connect to preferred network" option selected... but I want to fully remove any non-preferred networks from even appearing in the list? We get a lot interference from neighboring networks (some secured, some not) and some of my users are inadvertently changing their network connection.
tx
