Help - Can't connect to password-protected home network
Apr 03, 2008 4 Replies
Jump to replies (4)
I have an R40 with XP Pro w/SP2. I use it at several wireless locations and everything works OK. However, when I try to use it at my son's house I cannot connect to his password-protected network. I can find no place to enter the password!
The R40 is using the ThinkVantage Access Connection software. Obviously, I am doing something wrong but I can't figure out WHAT!
I have checked the "use Windows to connect to wireless network" (?) box but that didn't help.
Should I disable ThinkVantage? If so, how do I do it?
TIA
Chuck
Hi Could be that checking the box is not working right. Make sure that Windows Wireless Zero Configuration (WZC) is actually running, and that the vendor's Wireless Utility stopped.
(MVP-Networking).
In addition to what Jack said, perhaps your son's wireless network is using a higher level of encryption (WPA2-PSK for example) than your wireless adapter (hardware) can handle. How old is your R40?
Malke
If it shows in Control Panel > Network Connections: right-click on it > Properties >
Wireless Networks > Select it in Preferred Networks > Properties > Association and enter the authentication, encryption, key
in looking at the wireless connections, you need to find the place - in XP or via your custom Access manager to define the SSID and the connection security type - WEP, WPA, etc That is where you enter the "key" to access your son's network. It's a connection "key" vs entering a password like you were logging onto something.
