Force wireless connections by MAC addresses?
May 21, 2005 2 Replies
ANTant
Ralink card? How did you find that out? I thought it was using WiND chipset? takes me to Intel's Web site. Maybe. I cannot confirm it and I am not taking any chances. Where can I get it assuming it is supported. Envara Utility doesn't have this feature. :( I got the driver and…
Hello.
I recently read about how there are public WAPs/hotspots out that can be dangerous as dummy/fake ones (evil twins). Are there ways to connect to the correct WAP based on MAC address?
I recently saw two WAPs that had the same SSIDs, but with different MAC addresses:
00-0C...
00-0F...
One of them goes up and down, and I am assuming that is the evil twin and could be dangerous to be on (don't want to take the risk). In my Envara Configuration Utility v2.5.1 (3/18/2004) in XP Pro. SP1-SP2 (all updates) with a Hawking Technology's Hi-Gain USB Wireless-G Adapter Model: HWU54D), I cannot seem to force connecting to one. I believe it gets confused because there are two exact SSID names seen.
Thank you in advance.
Where can I get it assuming it is supported. Envara Utility doesn't have this feature. :( I got the driver and software from
I have that hawking tech card, its actually a ralink card. I have two AP's on one LAN with same ssid's and same encryption's, different channels, different MAC's. Of course when I am near one it has great signal while the far one is somewhat weaker and variable. Maybe somebody's hacked it and made it a man in the middle, evil twin,, ya think ?
The raylink utility has check box to allow fast roaming at any level signal [-70 default] dbm, but it'll choose best signal at windows start up.
