Firewall
Dec 29, 2005 2 Replies
You're talking firewall here and if you had a router or firewall appliance that did traffic logging, then you would clearly see and pick-out which machine on the LAN by IP that was doing it.
Long
Short
The tools in the link above may help you pin point the machine.
You may also want to look into packet sniffers.
Duane :)
Firewall open original image
Dear Friends,
In our wifi network, the entire network goes slow because of some pc broadcasting packets continuously. Can somebody help me how to isolate it without disconnecting it physically. Internet from our upstream ISP goes to the server and from there it goes to a L3 switch and to a AP
shanks
Thanks my friend will look into it
shanks
