EAP-TTLS problem..
Dec 03, 2007 0 Replies
Hi All, I am configuring wpa supplicant to use EAP-TTLS on wpa supplicant ported to marvell 8686. But have few raod block. Plz help me to solve the issue. luckily i am not getting any error in RADIUS server side...
  1. Getting SSL connect error.
SSL: SSL_connect:before/connect initialization
SSL: (where=0x1001 ret=0x1)
SSL: SSL_connect:SSLv3 write client hello A
SSL: (where=0x1002 ret=0xffffffff)
SSL: SSL_connect:error in SSLv3 read server hello A
SSL: SSL_connect - want more data
SSL: 102 bytes pending from ssl_out
SSL: 102 bytes left to be sent out (of total 102 bytes)
EAP: method process -> ignore=FALSE methodState=MAY_CONT decision=FAIL
  1. EAP entering failure state
EAP: EAP entering state FAILURE
CTRL-EVENT-EAP-FAILURE EAP authentication failed
EAPOL: SUPP_PAE entering state AUTHENTICATING
EAPOL: SUPP_BE entering state FAIL
my wpa_supplicant.conf as below
update_config=1
eapol_version=1
ap_scan=1
fast_reauth=1
network={
ssid="3Com"
scan_ssid=1
auth_alg=OPEN
proto=WPA
key_mgmt=WPA-EAP IEEE8021X
pairwise=TKIP CCMP
group=CCMP TKIP WEP104 WEP40
eap=TTLS
identity="jbibe"
anonymous_identity="jbibe"
password="whatever"
priority=2
phase2="auth=MD5"
-Raghu
